dual timing chain
Started by jim 94 yota, December 13, 2013, 05:09:22 PM
jim 94 yota
i just pick a used 22re well my fiance got it for me for christmas from an old man he said it came out of a truck he was drive but was rusted out it has just under a 100,000 on it i started pulling it down to check bearing an put new seals in it an it has a dual row timing chain on it but timing cover is same as my motor an it is for sure a 22re motor an it didnt come with any egr system it also has steel chain guides i just trying to figure out if i sould order a stock timing chain or a dual row
emsvitil
Dual row is better.
You need to figure out if it's an early 22re with a dual-row or a late model 22re with the LC Engineering dual-row conversion kit as the chains aren't the same length (98 vs 96 links (early vs late))
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
jim 94 yota
i forgot to say tat valve cover says 22re an the block says 22r it also has a vaccum advance dist an a mechanical fuel pump so i think it is a 22r if so would tat make it a dual row factory an if so should i worry about changing it at just 100k on it an wat years should i order parts for
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
tgmaul88
never believe the valve cover lable
pumkin toy
if it has steel chain guides in it, then the chain has most likely already been changed.  I could be wrong, but I don't think the factory engine ever came with steel guides.  Every one I have ever worked on had plastic guides, so we always upgraded them to the steel ones when changing the chain.
Why do you want to change the chain?  just because of mileage?  if the chain is not loose and isn't slapping against the guides or timing cover, then there really shouldn't be any reason to change it anyways.
97 4runner Limited
jim 94 yota
it is a 98 link chain so it is a factory dual chain i want to change it cause im just goin through the engine before i put it in my truck when i took the chain off this morning i noticed that it has rubbin the striaght guide bolts but it wasnt that chain that did it im ne to the dual row as i have a single in my truck now i replace it every 50k or once a year because i run it hard does any one know the toyota service for the dual row an what years i should order parts for this motor
jim 94 yota
thank you all for the help it is a early block now i am still wondering if i should just go ahead an change the chain an on that does anyone one know of a good reliabe place to get a timing chain kit that come with say water an oil pump and steel guides i was buyin my single chain kit like that from a place in cali off a website starting to look my self now but help is always welcome thanks agian for the help
tgmaul88
partsdinosaur.com/
www​.engnbldr.com/
www​.22reperformance.com/
rockauto.com
www​.lcengineering.com/
jim 94 yota
thank u all for the help i got parts orderd an block an head at machine shop
Rocks For Brains
22RE does not come with a mechanical fuel pump you have a 22R not a 22RE. 22R's have 2 versions the short block and the long block, which makes a big difference on parts. The short is the early version and the long is equal to the 22RE which it sounds like you have.
emsvitil
Quote from: Rocks For Brains on December 18, 2013, 12:53:39 PM
It's the other way around.
The newer 22r blocks are shorter than the older blocks.
And 22Rs came in the older and newer blocks.    I'm not sure what year 22REs where introduced, so they may only come in the later (shorter) block.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Ha ha, I'll have to vouch for him he knows which is which, must of had something else on his mind when he mixed them.
jim 94 yota
i knew it was a 22r i was manly trying to figure out if it was a stock dual row timing chain or a aftermarket one the block i have is a 81 to 83 with stock dual row figured tat out thanks to you guy helpin so thank u all i should be putting it in my truck next week pick it up friday from machine shop
