Our second $1,000 Holiday Wish List Give-A-Way!
Started by BigMike, December 05, 2013, 05:49:43 PM
Wolfe
http://www.marlincrawler.com/wishlist/1440
2- Yukon HD 4340 Chromoly Rear Axles
1- High performance Yukon replacement Ring & Pinion gear set for Dana44 in a 5.38 ratio
1- D-Ring Shackle
1 - $250 CRAWL CARD Gift Card
1 - $100 CRAWL CARD Gift Card
1 - $50 CRAWL CARD Gift Card
1- 3in Turtle Sticker
DanStew
My Wish List
http://www.marlincrawler.com/wishlist/1443
Pretty simple
4.88 gears for front and rear
install kit for gears.
cyberhorn the dragon
Zs Confederate Toy
Thanks for another opportunity!
Link:
http://www.marlincrawler.com/wishlist/227
List:
1 Dual Case Kit $399
1 High Performance Headlight Kit $79
1 HD Knuckle Gusset Kit $89
1 IFS Spartan Locker $373.15
7 Low pro magnetic drain plugs
2 Turtle Shift knobs $20
1 Turtle plate $5
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
HiluxDiesel
http://www.marlincrawler.com/wishlist/1434
Mostly parts to keep the rig running and then a couple of dream items.  Thanks Marlin for the many years
of wisdom.
HD pinion seal
HD cross member mount
HD shift spring
R151 rebuild kit
HD clutch
Caliper mount bolts/washers
HD 25 steer pin upgrade
*Twin shift kit (if in stock instead of HD 25 steer pin upgrade)
*Hilux gear drive transfer case rblt case kit (if in stock)
*Big bore FJ80 master cylinder (if in stock)
Have to rearrange list a bit if things get back in stock.  wh
noredcoat
http://www.marlincrawler.com/wishlist/259
1.   Gear Drive, Right-hand output, $999.00
2.   G52, $1,319.00
3.   Clutch Fork Boot for 1981-1995 applications, $15.66
4.   Shift Handle Boots, $7.03
Mudshiner44
http://www.marlincrawler.com/wishlist/1445
Heck yeah!!!
   Full Face Differential Armor
   $138.00
   Transfer Case Shift Handle and Knob
   $118.00
   Boot, Interior Floor
   $55.00
   Speedometer Extension Cable
   $39.00
   Crossmember Mount, HD (old)
   $75.00
   Gasket and Seal Rebuild Kit
   $49.00
   Dual Case Kit (MC07-XD)
Currently
Out Of Stock   $0.00
Alberta4x
http://www.marlincrawler.com/wishlist/1447
   V6 IFS Front Brake Caliper (left) $129.00
   V6 IFS Front Brake Caliper (right) $129.00
   Brake Pads Late Style $29.99
   Turbo Clutch Upgrade Combo Kit $299.00
   12mm Upper Knuckle Stud Kit $59.92
   Chromoly Rear Axles (2) $306.46
Very cool contest idea! Thanks for the chance!
yotamantrav
Link:
http://www.marlincrawler.com/wishlist/1449
List:
Front Bumper $399
LED rock light strobe kit $139
Optimus LED driving light kit $299
HD knuckle gusset Ket $89
Full Face Diff armor $69
Turtle plate $5
miillatime
This would make my year!  :beer:
http://www.marlincrawler.com/wishlist/1448
Yukon Ring and Pinion Gear Set   Toyota 8" 4cyl x 2
Yukon Ring and Pinion Setup Kit   Toyota 8" 4cyl x 2
Marlin Crawler RF1A Gasket and Seal Rebuild Kit
Big Bore V6 Master Cylinder
Funtreks Southern California Trail Guide
Rear Axle Service Kit   Rear Axle Service Kit, 1979-99
mlee12382
http://www.marlincrawler.com/wishlist/1112
Marlin Crawler 4.70:1 Xtreme Duty Low Range Gear Kit   4.70:1 XD Gear Kit
Top Shift Conversion Kit
Marlin Crawler Chromoly Front Output Shaft   30-Spline Chromoly Front Output Shaft
30-Spline Chromoly Rear Output Shaft
Heavy Duty IFS Steering Box Mount Kit
Marlin Crawler Crawl Box Top Shift Conversion Kit   Shift Kit, High/Low
JDC
http://www.marlincrawler.com/wishlist/1454
Thanks Marlin Crawler for this generous give away!!
My 92 4Runner could use a new W56 tranny to go with my dual cases.
Sharpie330
#73
http://www.marlincrawler.com/wishlist/1453
First time posting on this forum, might as well be for a raffle.
* 2x D-Ring Shackles
* 4x Bilstein 5125 series 12" shock absorbers
* 2x Aisin manual hub lockers
Thanks for the chance to win  :usa:
John 3:30 He must become greater, I must become less.
Dezertdanny
swilson
http://www.marlincrawler.com/wishlist/1457
Merry Christmas!
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
Slow5oh
Cnjensen
Thanks for the opportunity
* The Unique Link to your Wish List is: http://www.marlincrawler.com/wishlist/1458
Wish list settings
   LED Rock Light & Strobe Kit
   Zip Locker 8" 4cyl
Duffil
 I'm in! :yesnod:
http://www.marlincrawler.com/wishlist/1462
23-spline 4.70s
R151f ShortThrow Shifter
Yukon 8" setup kit
Solid Pinion spacer
helipilot77
#80
Merry Christmas to all my rock crawling companions.
30 spline chromoly output combo kit
R151f minor rebuild kit
Led rock light and amp; strobe kit
25mm steering pin upgrade kit
lowdowncoyote
Come-on Lady Luck! I just nuked my rear differential...
http://www.marlincrawler.com/wishlist/1330
-ARB equipped replacement rear diff
40Habits
This would keep me busy over the winter!! :crossed:
Four Pattern 30-Spline Flange
Yukon Ring and Pinion Gear Set Toyota 8" High Pinion
Zip Locker 8" High Pinion
Yukon Ring and Pinion Gear Set Toyota 8" V6
http://www.marlincrawler.com/wishlist/449
BWilliams
Sold off the crawler for the family now building a dual purpose FJ40 LC
ruegs21
Wish list:
* Chromoly 30-Spline Axle Kit for 1979-85 Hilux axles
* Toyota 9.5" Land Cruiser Yukon Gear 4.88:1 gear set.
* Toyota 9.5" Land Cruiser Yukon Gear differential setup kit.
Wish list link: http://www.marlincrawler.com/wishlist/1015
93 4Runner, 5VZ, A340f, Duals, Lockers etc
kevin88x
#87
Hey Marlin Crawler,
Thanks for the opportunity and Merry Christmas to all, may my wish come true...lol
Unique Link: http://www.marlincrawler.com/wishlist/605
Toyota 8" E-Locker Yukon setup kit
Toyota 7.5" Reverse Rotation Yukon setup kit
Toyota 8" E-Locker Yukon Ring and Pinion
Toyota 7.5" Reverse Rotation Yukon Ring and Pinion
Dalton726
Unique link: http://www.marlincrawler.com/wishlist/1465
Chromoly 30-spline axle kit for 1979-85 hilux axle
Front bumper with weld on stinger
Thanks Marlin for the opportunity!
fast65chevelle
