Our second $1,000 Holiday Wish List Give-A-Way!
Started by BigMike, December 05, 2013, 05:49:43 PM
jtaco1
Thanks for the chance Marlin and Crew.
Here is my unique wish list link:
http://www.marlincrawler.com/wishlist/1494
and here is my list:
Long Spline Drive Shaft Kit
30-Spline Chromoly Rear Output Shaft
30-Spline Chromoly Front Output Shaft
Hoodie
Turtle Shirt
Thanks again,
JT
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, Elocker rear axle, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
ajoebob
http://www.marlincrawler.com/wishlist/1495
I need some headlights, a cage, long travel driveshaft, 4.7 case gears, or a gift card.
esh
Happy Holidays!
http://www.marlincrawler.com/wishlist/1496
Marlin Crawler Metallic Clutch Kit   Heavy Duty Clutch Kit (1,200 lb)   $219.00
Steering Pin Upgrade Kit   25mm Steering Pin Upgrade, Kit   $249.00
Spindle Nut Kit   Spindle Nut Kit    $17.58
Marlin Crawler Backing Plate Eliminator Kit   Backing Plate Eliminator   $60.00
Drive Line Flange Nut, M10   Drive Line Flange Nut, M10   $13.56
Marlin Crawler Turtle Plates   Turtle Plates   $20.00
Headlight Adjuster   Headlight Adjuster   $9.96
Powertank Tire Inflator with Gauge   Tire Inflator   $69.95
Marlin Crawler Full Differential Armor   Full Face Differential Armor   $138.00
Transmission Rebuild Kit   W56 Kit, 1985-91   $299.00
It would have been longer but I just bought a bunch of goodies from the black/cyber sales.  :beer:
Cascade Cruisers, TLCA #4408
'64 FJ40, '66 FJ45,'79 FJ40, '81 BJ42, '82 BJ42, '85 XCab SR5 p/u, '89 FJ62
the dude
Thanks Marlin Crew!
http://www.marlincrawler.com/wishlist/1499
   18mm x 1.50mm Tap   18mm Tap, Drain or Fill Plug
   Marlin Crawler SST Knuckle Alignment Tool   Knuckle Alignment Tool
   Brass Spindle Axle Bushing   Spindle Brass Axle Bushing
   Birfield Seal Installer   Inner Axle Seal Installer
   Powertank PT10 Package A   Powertank PT10-A Kits
longjohn91
Chance to finish my rig
http://www.marlincrawler.com/wishlist/1497
Marlin Crawler Chromoly Front Output Shaft   30-Spline Chromoly Front Output Shaft
   $249.00
30-Spline Transfer Case Output Shaft   30-Spline Chromoly Rear Output Shaft
   $474.00
V6 Vented Caliper   V6 IFS Front Brake Caliper
   $129.00
   $129.00
Marlin Crawler Warning BIG NUTS REQUIRED Sticker   "BIG NUTS REQUIRED" Sticker
Currently
Out Of Stock   $2.99
Low Profile Drain Plug   Low Profile Magnetic Drain Plug (Metal Gasket)
   $4.99 x 2
Marlin Crawler Ultimate Dual Transfer cases Sticker   "Ultimate Marlin Crawler" Sticker
   $4.99
Thanks Marlin
Mavericks
Thanks for the chance to win!
http://www.marlincrawler.com/wishlist/421
Brake Caliper and Rotor Combo
High Performance Replacement Headlights
Big Bore V6, Brake Master Cylinder
Crawl Card Gift Card  $500
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
Hey guys, the Wish Lists look great! Keep em coming!! And remember, you MUST post both your unique Wish List link AND the contents of your Wish List to be eligible to win.
Most of the posts are done correctly but just like last year we have some who are not following the rules.
Therefore, if you only post your Wish List link and do not include what's in it, and your name is picked as the winner, we will re-run our random winner program to find a different winner who did include what's in it :wave:
Good luck to all and to all a Merry Christmas! :santa:
brandonbm
#127
THANKS MARLIN!!
http://www.marlincrawler.com/wishlist/548
25mm Steering Upgrade Kit w/ Arms
bakerscott7_12
http://www.marlincrawler.com/wishlist/1355
transmission shift knob
hilux chromoly rear axles
upper axle reinforcement gusset-solid
full face differential armor x2
bilstein 5150 14 inch x4
big nuts required x2
marjoint x2
extended brake line kit-hilux
Dan the Goat
http://www.marlincrawler.com/wishlist/1306
Here is my list which I updated for my 83 FJ60. I went a little beyond $1000.00 because I lost control of my self. My
truck owns my life!! I definitely would love the heavy duty high steer kit and and 30 spline chromoly  axle kit!!
My Land Cruiser loves you guys!!
hiluxor
elwood73
http://www.marlincrawler.com/wishlist/1505
Crossmember Mount, Locktup 4x4   Crossmember Mount, HD
   $150.00
Marlin Crawler New Front Bumper   Front Bumper
   $449.00
New Heavy Duty Rear Bumper   Rear Bumper for Hilux Trucks
Currently
Out Of Stock   $0.00
Marlin Crawler High Steer Kit   High Steer Kit for Hilux
Currently
Out Of Stock   $0.00
Heavy Duty Power Steering Box Mount Kit   Heavy Duty IFS Steering Box Mount Kit
   $55.00
mkyhmltn
Wow, Thanks for the chance! Heres my wish list.
http://www.marlincrawler.com/wishlist/539
Short Throw Shifter Kit, G54
Spool 8" 4cyl
Super Heavy Duty Clutch Kit (1,600 lb)
4.70:1 XD Gear Kit
Hope I win so I can be that much closer to getting this thing on the road
gtoboy
This would sure help with a rough year in my household, my 80 series project has stalled out.  :crossed:
I would love to do the 3.116:1 gears in my transfer case :turtle3:
The 4.56:1 in the diffs would really help with this as well :turtle3:
1. 80 & 100-series Land Cruiser Crawler Gears Land Cruiser Crawler Gears      $799.00
2. FJ80 Heavy Duty Front Inner Axle Seals HD Inner Axle Seal                        $23.98 x2
3. Marlin Crawler's Electric Locker Motor Guard Electric Locker Motor Guard     $49.00
4. Yukon Ring and Pinion Gear Set Toyota 8" High Pinion  (4.56 ratio)             $355.93
5. Yukon Ring and Pinion Gear Set Toyota 9.5" Land Cruiser (4.56 ratio)        $241.53
http://www.marlincrawler.com/wishlist/639
Thank You and happy holidays
skid
 :beer:
http://www.marlincrawler.com/wishlist/1507
Caliper Hard Line
Rear Axle Service Kit, 1979-99
Vented Brake Rotors   Standard Vented Rotor
Extended Brake Line Kit, Hilux
Heavy Duty Bearing Cover Plate, R-series
Billet Shift Fork, R-series
Chromoly R-series Thrust Washer Kit
R150F Minor Rebuild Kit (1988-10/91)
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
Jew Ballin
http://www.marlincrawler.com/wishlist/1508
Snap Ring Pliers   Snap Ring Pliers
   $24.99
C-Clip Pliers   C-Clip Pliers
   $24.99
Permatex Ultra Grey Silicone   Silicone Ultra Gray
   $4.49
Monster Valve Kit   Monster Valves
   $159.95
   $69.95
D-Ring Shackle   D-Ring Shackle
   $30.00
Marlin Crawler CRAWL CARD Gift Card   CRAWL CARD Gift Card
   $200.00
YG-YAW48208   Yukon 4340 Chrome-Moly replacement inner axle for Dana 60, '77-'91 GM
   $215.59
YG-YAW48210   Yukon 4340 Chrome-Moly replacement inner axle for Dana 60, '80-'86 GM Chevy 1 Ton, '79-'90 Dodge
   $244.74
SNOW WALKER
http://www.marlincrawler.com/wishlist/1509
front bumper
a set of 4.70 gears
I'll gladly pay the difference in price. LOL
1986 4Runner turbo sas high pinion,E-locked 4:88's,taco rear Detroit locker,22ret forged everything,
duels mc07-r10 cut 42's.
Squishy!
RiskyRicky
Thanks for the opportunity, Cheers Marlin!
MY LIST
  • Transmission Turtle Shift Knob
  • 4.70:1 XD Gear Kit
  • Triple Drilled Differential Flange
  • High Performance Replacement Headlights
  • 2x Bilstein 5150 series 14" flavor
  • Turtle Plate
  • 12mm Knuckle Stud
http://www.marlincrawler.com/wishlist/1510
89 4Runner SAS 37" DC locked
johnny_boy02
This is such a cool giveaway.
I need to stock the trail toolbox, dress up the truck a bit and upgrade a few things.
http://www.marlincrawler.com/wishlist/1513
1) 25mm steering upgrade kit w/ arms
2) LED Rock light & amp Kit
3) Snap ring pliers
4) C-clip pliers
5) T50 Torx socket
6) 10mm allen head socket
7) E12 socket
8) Billet aluminum t-case knob
9) Driveline flange nut x's 10
10) Driveline flange bolt x's 10
11) Brake line mounting L bracket x's 4
12) Transmission shift knob (black)
13) Northern CA Trail book
14) Airline splice x's 2
15) Airline spool
16) Tire inflator
17) Front axle service kit
I think I am a bit over but taking something off or paying the difference is no problem.
Thanks guys
reformed
http://www.marlincrawler.com/wishlist/1516
1. Chromoly 30 spline axle kit 79-85 pickup/4runner-549.00
2. Transmission Shift Knob-49.00
3. Front Bumper 86-89 4Runner no stinger-399.00
Thanks for the opportunity for this giveaway, very cool!
sp543
http://www.marlincrawler.com/wishlist/1518
USA Standard Gear's Ring and Pinion Set 5.29   Toyota 8" 4cyl, USA Standard
   $160.34
Yukon Ring and Pinion Gear Set 5.29   Toyota 8" V6
   $225.96
Yukon Ring and Pinion Setup Kit   Toyota 8" V6
   $257.15
Yukon Ring and Pinion Setup Kit   Toyota 8" 4cyl
   $169.25
   $100.00
   $50.00
Thanks!
coryc85
Wow, another year gone.  Thanks for doing this wishlist giveaway again!
Here is my unique link: http://www.marlincrawler.com/wishlist/718
And Here are my items:
1) w56-b transmission
2) heavy duty clutch kit
3) ARB builder package 7.5in, with Yukon 4.88s
4) 58" Marlin Sliders
trailrig
http://www.marlincrawler.com/wishlist/1521
I went over :rivers:
Crossmember Mount, HD 2
Premium Superwhite Headlight Bulbs 2
Rockin4Runner
Thanks Turtles  :thumbs:
http://www.marlincrawler.com/wishlist/1520
HD Shift Spring   Heavy Duty Shift Spring
Marlin Crawler Hoodie Sweater   Hoodie
Brake Line, Male-female   Extended Braided Brake Line Male-Female
Brake Master Cylinder   Big Bore FJ80 Brake Master Cylinder
YG-YTP20   The Yukon Carrier Bearing Puller
Front Manual Locking Hub   Free Wheel Hub Assembly
Front Axle Service Kit   Front Axle Service Kit
Marlin Crawler Long Spline Heavy Duty Driveline   Heavy Duty Long Travel Front Drive Shaft
zembalayan
Awesome promotion!
Here is my wish list link:
http://www.marlincrawler.com/wishlist/572
Here are the items on my wish list:
ARB Air Locker, Landcruiser Non C Clip, Model RD-142
Marlin Crawler's 30-spline Front Output Shaft
Marlin Crawler's 30-spline Rear Output Shaft
Thank you.
Wish list link:
http://www.marlincrawler.com/wishlist/393
Wish list items:
2 Full face 85 Hilux diff armor  $138.00
1 Heavy Duty Knuckle Gussets  $89.00
1 Rear 8" spool equiped 3rd member w/5.29:1 gears  $849.00
I will happily pay the difference.
Ron
boomtacoma01
http://www.marlincrawler.com/wishlist/336
1200 lb clutch kit
8" 4cylinder Spartan locker
25 mm steering upgrade
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
