Hi steer conversion
Started by samhell1985, November 14, 2013, 06:03:18 PM
samhell1985
So I have an 85 pickup with the push pull style stock steering. I'm running 35's so my steering is absolutely ridiculous.soon I plan to switch to hi steer, however I haven't really found a complete list of what I need. Do I need a power steering box and a pump? How is the pump added in with my motor? And how much longer of a belt would I need? I'm running a 22r carbed. Any help or explanation would be appreciated. :turtle:
Box you up like Tetris.
tgmaul88
#1
you need the complete high steer kit (i suggest marlins) get a 86 + IFS steering box, and ifs steering box mount (marlin), steering dampner, a front hanger,  with the power steering you need the pump, lines, brackets, and resi and a extra pully for the front crank shaft
tgmaul88
very well worth doing, not to difficult, but you will need to weld
samhell1985
Slolyfe
Welcome!
I ran a nonpower steering box, stock hanger, and no steering stabilizer for years as a daily driver on 33's and never had any issues. They when I got the money just upgraded the box and added the power steering stuff.
You'll never take me alive
samhell1985
Thanks for the welcomes, slowlyfe how was the bump steer and handling with your setup?
brockbuilt85
i run a stock hanger to keep my profile low (less lift) and so far so good. depends of if your stock hanger is beat up, mine was almost too beat up, but i got it to work. other than that all the stuff listed here. im assuming running 35s you have a lift or ruf or?
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
samhell1985
Yeah I have a five inch lift, got the pump and the box today, I still need the line cooler and replacement hoses
