Author Topic: First gen Emission control box fix!  (Read 7607 times)
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
« on: Sep 20, 2013, 12:17:49 PM »
This Thread is Featured in our Tech from our Forum Members section!
       If you are having idling problems with your first gen Toyota then you need to take a look at the emissions control box. Over time some of the joints on the circuit board will break loose causing a bad connection. I am going to try to show you guys how easy it is to fix.  :thumbs: You are going to need a soldering iron, 63/37 rosin core solder, rubbing alcohol, and a toothbrush.
The box
The problem area
This is the connection on the front that breaks
You can see all the fine cracks in the solder joints.
Take your toothbrush and apply some rubbing alcohol to it and brush it over the broken solder joints. This helps remove any dirt or old flux on the joints.
   When they are nice and clean take your hot iron and tin it (tinning). To properly tin your iron you heat it up apply some solder to the tip and then gently wipe it on a wet sponge to spread it evenly over the tip. Tinning the iron helps remove oxides and helps spread the heat to the joint.
   Then take your tinned iron to the first broken joint and heat it up and add your solder. It should take you about 2-3 seconds per joint. Any longer and you can burn up the circuit board. Also remember to wipe your iron on the wet sponge after every joint to keep it clean and remove oxides. They should be nice and shiny when you are done.
You can see the left side all done.
All done! :biggthumpup:
My fancy tools!  :haha:
« Last Edit: Sep 20, 2013, 04:04:02 PM by BigMike »
CrazyYota [OP]
  • Turtle Points: 92
  • Male Posts: 1,073
Re: First gen Emission control box fix!
« Reply #1 on: Sep 20, 2013, 12:21:42 PM »
Here is a pic of one a smog shop charged my dad $300 bucks to fix! :shocking: Looks like it got a little hot! I think they used the wrong solder and flux. So save yourself some money and fix it yourself! :biggthumpup:
rattlers
  • Turtle Points: -68
  • Member since Mar '11
« Reply #2 on: Sep 20, 2013, 01:09:04 PM »
hello thanks for the write up, do you know if the 85 4runner has one of these boxes or simular and where its location is.  thanks
__________________________
ll_______ll_______ll__TOYOTA_ll
ll_______ll_______ll____85____l
CrazyYota [OP]
  • Turtle Points: 92
  • Male Posts: 1,073
« Reply #3 on: Sep 20, 2013, 03:54:49 PM »
I think the 85 had them on the passenger side kick panel where the computer for the EFI would be.  :biggthumpup:
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #4 on: Sep 20, 2013, 04:07:06 PM »
Nice write up and pics CrazyYota! :clap2: I added this thread to our main Tech page :thumbs:
CrazyYota [OP]
  • Turtle Points: 92
  • Male Posts: 1,073
« Reply #5 on: Sep 20, 2013, 09:42:53 PM »
Sweet! I hope it helps keep another first gen going!  :driving:
Rokntoy
  • Male Posts: 43
  • Member since Jan '06
« Reply #6 on: Oct 19, 2013, 09:30:09 PM »
I had forgot about that thing and mine is running rough Thanks for the fix!
flopp IT!!! WE'LL DO IT LIVE!!!!
bjewett
  • Member since Feb '21
« Reply #7 on: Feb 07, 2021, 04:53:50 PM »
I couldn't get my 1983 pickup to pass smog. Just a little too high maybe 10-15% high on HC. Random stumbling idle. Stalling after 15 seconds of perfect idle or coming to a stop. Days of troubleshooting and throwing money at the problem. Rebuilt the carb, cleaned the egr, new vacuum lines, plugs, cap, rotor, wires, oil change, cleaned and added dielectric grease in every connection. I was so defeated. With one last ditch effort I found a link to this thread in a yotatech forum. This was the fix. I took me 15 minutes to execute. Thank you so much!!!
1983 Pickup DLX, 1981 Pickup SR5, 2010 FJ.
Last post Jul 28, 2006, 06:33:01 PM
by wildchild1066
Last post Sep 04, 2007, 08:12:51 PM
by Wermz84
Last post Jun 15, 2009, 05:17:46 PM
by THK Matt
Last post Mar 24, 2012, 09:05:13 AM
by 84ToYSr5
Last post Aug 16, 2012, 07:38:20 PM
by CrazyYota
