Front and rear third differences
Started by Moit88RNR, September 01, 2013, 08:24:40 AM
Moit88RNR
I have a spare rear third. Wondering if I could do the gears in that, then swap it in my front.  :-\
hansi530
it doesn't matter aslong as the ratio is the same it will be fine
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
mudmaster
Time to go wheelin!
Moit88RNR
I was thinking you would be on the coast side instead of the drive side of the gears
Moit88RNR
Also thinking that in that in that case it wouldn't oil right
Toyota gears are not reverse cut for the front, about the only thing would be how they were originally broken in as to the actual strength on the front or rear. A broke in rear will be a little weaker in the front since steel has memory. This is one of the reasons that when you pull a stuck vehicle you don't want to pull with your rig going backwards since you are now on the weak side of the gear or as you put it the coast side, the side of the gear doesn't matter when it was broken in on the coast side.
Moit88RNR
Ok so if I build my Spare diff. I want to make sure I break it in in the position (front or rear) that it will stay? If you switch from front to rear or vise versa, would it help to do a break in period again or is it pointless at that point?
Thanks Rocksurfer. That answered my question. I guess I was just over complicating it.   :beerchug:
If I were to break in a spare it would be in the rear since it won't be on the coast side, you are more likely to break the rear over the front since that's where most of the load will be. Usually you will break something else in the front before a gear.
OOPS
Quote from: Moit88RNR on September 01, 2013, 08:24:40 AM
Yep. that is done all the time. Just make sure the gear ratios are the same.
ecrum428
Nice, just the info I was looking for.
Crunchy Taco
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Saved-wheeler
Toyota wizards!
Sent from my SCH-I545 using Tapatalk
