Diggin the build man.
sweet what the lengh?
wow thats long for one piece. Did you consider a two piece.
That makes sense. Dude good for you on the grad school. Few years now benefits the rest of you life.
Just read the whole build. Beautiful. Continue with updates.
Well congrats on the grad school! What is the focus?Maybe if you take two years for grad school my t100 might be done by the time you are done and we can go play. Lol
My focus is Mechanical Engineering.Sounds good to me assuming she is running the way I want her to. She is due for a new timming belt and I need to rebuild the motor since she has just under 250K on the stock motor. I also have many other things I want to do to her before she is trully ready but I should be able to get her up and going in a decent amount of time once I'm back. I'm always down to go wheeling. What is your plan for your T100?
any specialty in mechanical engineering? like heat transfer, fluids, etc? i am a mechanical engineer also is why i ask. my t100 has 366k on the stock motor and besides the cracked head and exhaust manifold, the compression was still in spec and oil analysis came back good.i am just now collecting parts since i sold the 1st gen but i have some widened fj axles 5.29's detroit and spartan, 37" yokohama m/t's air bumps for the front and dual ultimate cases. i still need to buy coilovers, rear springs, and build the front 3 link. it is going to be a wait until i can cut her apart, but if all goes as planned by next spring i will have all the parts collected and sparks will start flying.
Right now my focuses are on mechatronics and digital manufacturing. My third focus will probably be a combination of dynamics of systems, composite structures, materials and their properties and a dash of manufacturing. What are you doing as a mechanical engineer?I know mine doesn't really need a rebuild that bad but shes eating oil right now and I've already burned through two injectors so I figured if I'm replacing the timing belt anyways its not much more work to rebuild the motor since the motor will be mostly torn apart anyways. Plus I will be almost exclusively wheeling her so tuning her up a bit sounds like a good idea. So you're sticking with Toyota running gear huh... out of curiosity why? The T100 is so wide that full sized axles fit under her like they were made to be there; plus the 1ton axles are stronger, more common, and easier to work on. The 5.29 gears should run great and supper slow with the dual cases. Did you get the dual cases from Marlin? I really want dual cases but I need other stuff first. I found that I had far more power with 5.13 gears and 37's than I expected... you should have even more power. Some day I will swap out the front leafs for coilovers but I'm gonna run the leafs as long as they get the job done. Good luck on your build! I look forward to seeing it on the forum!
my focus in my BS was thermo/heat transfer and fluid dynamics with a minor in material science (hence the composites class). I work designing piping now. first four years of work were in remote power generation but now i work in the food and beverage industry designing sanitary stainless piping for liquid food and beverage processing with a specialty in breweries and distilleries. I like designing breweries because of the taste testing...lol I have done the Dana 60 and 14 bolt combo before and they never broke but they added immense unsprung weight and parts cost was significantly higher than the toyota stuff. also, i really like the 3rd member design vs the cast housings on the dana axles and the gear setup in the toyota stuff is way nicer than the dana stuff (no case spreader needed). cheapest or easiest route from scratch, no, but for me i already have most of it so it is my cheapest route, and at a similar strength to one tons without the extra weight and the cool factor from being all toyota.trying to make the T100 toyota the way it should have been made in the first place...lolor could be me just being a nerd and over engineering a simple axle swap and having too much time to dream.... you can be the judge...as for the ratio, i was slightly worried the 5.29 would be too low for just 37's but like i said i already have them and if i dont like them on the freeway i can always find the parts for the R452 5th gear swap and go to a taller 5th for the freeway and still have the benefits of the lower gearing everywhere else. IIRC i calced the 5.29's and 37's to be around 2850 on the highway. i think 4.10 and 31's were around 2600 so with the R452 5th it would put me right about the 2600 mark.as soon as i get the truck back from the top end rebuild i will get some pictures and some pictures of the parts pile that has started.
Your designing breweries!!! Thats so cool! I would like the taste testing too. I miss the good Oregon beer back home. There are some good beers from back home here but they are about $5 or $6 a bottle so I don't get them often. Where did you go to school for your BS?The 1tons are deffinitely heavier but for me it was the easiest way to go... I got the set for $600 which is half the cost of just the front axle. I have never needed a spreader to remove the carrier. Just a little persuasion was needed to get it to do what I wanted. I agree whith you on the fact that Toyota should have mimicked their design from the first gen Toyota pickups and ran a solid axle... I think its one of the biggest downsides to all modern Toyotas. Did you try the websight I used to see what your speeds would be? I posted the link in an earlier post on the first page. Very usefull and fairly acurate. I think mine said I would be going about 75-80mph in 5th @ 3000rpm. Because if the rpm limit on my driveshaft I was never able to test it but I was able to test 4th gear @ 3000rpm which resulted in about 55-65mph and the sight said I should be going somewhere in that range as well. I believe the T100 has the R150F transmission and not the R151F. However, the only difference is that 1st and 2nd in the R151F are lower than the R150F. The picture is the calcs for my truck.
where are you going to grad school? i bet you can find good local beer near you as well. should ave taken the t100 with you, bet you could find some wheeling near you.600 is a screaming deal. most dana 60 fronts i see down here are 1000-1500 stock.i really like this page on Grimm Jeeper for gear ratio calc:http://www.grimmjeeper.com/gears.html
maybe you can find some diesel crew cab hiluxes while you are there and mail them back piece by piece....lol
Started by BIG-T Project Research and Build-Ups
Started by yota_krawler « 1 2 » Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by climber87 Project Research and Build-Ups
Started by toyofan7987 Parts Wanted
Started by T-100 tank Project Research and Build-Ups
