noob to the place
Started by 88sasturbotoy, May 27, 2013, 10:01:03 PM
88sasturbotoy
Hey guys figured I'd introduce myself I'm new to the board but not new to toyotas been building them for about 5 year now and I think I finally got the one I'm gonna hold onto for a bit. Anyways my rig I own now is a 1988 toyota (of course) xtra cab solid axle swapped pickup got about 6 inches of lift or so sitting on mickey Thompson mtzs. The  work I have done includes 5 speed swap 4.7 Low range gears front solid axle swap rear long travel leaf spring relocated the shocks to the top of the axle front and rear welded now my pride of this truck is the motor......I've got a 22r te turbo motor that is bored .04 Over head is brand new ported polished and a couple other secret things haha turbo is Garrett tea turbo spools about 15 to 18psi depending on how it hit it  ive got tons of work on the motor the suspension wasn't the hard part on this rig the motor and tuning the motor....welp hope you guys can welcome me to the family as I planon staying here for a while giving all the info iI can and iI can give alot of info expecially on the turbo edition  Toyota offered
88 xtra cab pickup solid axle swapped 5spd swapped 4.7 swap turbo 15psi swapped = rowdy
toe
Me
Kyle20r4spd
 :welcome: to Marland from B-ham Wa. :thumbs:
Just put er' to the wood and it'll make it!!! -Dylan W.
Isn't ketchup technically a tomato smoothie???
:welcome: How much trouble was the conversion from Auto to Manual? Also, are you running an adapter between the stock Turbo manifold and the new Turbo or are you running an aftermarket Turbo manifold?
15-18psi sounds like :burnout: !
ajordan1975
monyman
2001 Tacoma double cab SR5: 3.4l V6, Diamond axles, 5.29s, duals, ARBs, PSC hydro, 4 wheel discs, 38.5 TrXus and stuff
88sasturbotoy
right now im running the adapter plate im in the middle of tryin to sell some things so i can get the new manifold probably gonna go with the lc manifold and actually the 5spd swap wasnt bad at all i got all the parts off of one of my buddies junkers all except for the 5spd and when im driving it down the road i usually run 12psi but when i get into it and try to make it run im around 15 to 18 and yeah it def is a good time haha
Nation
