Author Topic: Converting auto locking hubs to manual  (Read 999 times)
PETDOC
  • Member since Jan '10
« on: May 07, 2013, 06:47:33 AM »
I've got an '88 4Runner with auto locking hubs and will be getting the manual Aisin hubs this week. Project seems pretty straight forward, but I'm having difficulty on getting the torque settings for the 54mm nuts. As I currently understand the swap, after removing the auto hub I will need to place a washer next to the outer wheel bearing, followed by a 54mm adjusting nut, lock washer and finally 54mm lock nut. Can someone give me the torque for the adjusting nut and the lock nut?
 One additional question is what kind of grease should I apply to end of the drive shaft before putting the hub body in place? The hubs are coming pre assembled so they will already have grease inside them.
Thanks for any information.
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • Member since Mar '13
  • @nationallmotors
    • Buy me a soda
Re: Converting auto locking hubs to manual
« Reply #1 on: May 07, 2013, 07:42:58 AM »
Wheel bearing grease. Also not dure bout ifs bu my sfa. You have to pre load the bearing and het a special tool..almost like a fish scale and tighten the nut until it takes between 8-12lbs of force before you can turn it. Order urself an fsm
Nation
  • Male Posts: 1,565
  • @nationallmotors
    • Buy me a soda
« Reply #2 on: May 07, 2013, 07:46:32 AM »
By turning it i mean before the wheel hub is able to turn...
Last post Apr 12, 2004, 11:13:53 PM
by mr4x42u
Last post Mar 24, 2008, 07:57:37 AM
by 4RnrRick
Last post May 25, 2008, 06:43:39 PM
by lilbuddy
Last post Jun 03, 2008, 06:10:20 PM
by WHITE_TRASH
Last post Jul 05, 2009, 09:08:37 PM
by Joey88RUNR
