Transfer Case Replacement
Started by breezernate, April 24, 2013, 10:07:20 AM
breezernate
O.K.
I found a replacement used transfer case.  To replace it, must I remove the transmission and transfer case from the engine or may I only remove the case from the rear of the transmission?
Nate
Nate
nisota
6 bolts size 14mm hold the transfer case to the transmission you may drop the transfer case without removal of full transmission. Good luck
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
breezernate
Thank you!  This sounds like a real weekend adventure!
Picked up the case today...spilled gear oil all over the back of my truck.  Fun. Fun.  Rust treatment.
Nate
mudmaster
Good time to replace the rear xmsn seal too if needed.
Time to go wheelin!
nisota
Quote from: mudmaster on April 25, 2013, 10:33:04 AM
x2 Thanks forgot to mention this.
Oregon wheelin'
82' 2wd-4wd project
bleakhorizon
if your asking this im assuming you should know to disconnect the shifter.... and if its a forward shift you will have to pull it back untill the shift forks are out of the tailshaft of the transmission before it comes all the way down and out.
Those are some huge welds!
Tillamook, OR
breezernate
Oh, mine is a top shift.
From the top without the shift lever I see two tabs on two shafts.  I assume I need to orient the shafts aftward before pulling the transfer case.  Does this mean it need to be in 4H before pulling it and when putting the other one back in?
Nate
nisota
Quote from: breezernate on April 26, 2013, 12:25:08 PM
I pulled/installed mine in 2hi and it worked fine.
Oregon wheelin'
82' 2wd-4wd project
