Author Topic: Throttle sticks while under load in low low  (Read 1034 times)
yotaman198481
  • Male Posts: 25
  • Member since Mar '13
  • its a love hate thing with my truck
« on: Mar 25, 2013, 06:41:14 PM »
My throttle sticks in my 81 Toyota in low low while under a load. If i go into a hill climb at idle its stuck at idle and will not let me push the go pedel till i reach the top or push the clutch in. If i start climbing at half throttle it will stick there till i reach the top or push the clutch in. I am going crazy! I have new motor mounts and they dont look torn. Any help would be great. By the way the truck has the stock 22r.
Its never ending!
toyyota
  • Turtle Points: 5
  • Member since Apr '08
Re: Throttle sticks while under load in low low
« Reply #1 on: Mar 25, 2013, 08:26:21 PM »
I'd hafta say the motor mounts, took out your throttle cable where it passes through the firewall. Set your hand brake, have a buddy shift forward/reverse and feather the clutch and watch the engine rock. If you have a bad motor mount you can see the engine climb and twist. The throttle cable housing will crack and bind at the firewall. Last i needed one, cable is still available from Toyota dealer.
yotaman198481 [OP]
  • Male Posts: 25
« Reply #2 on: Mar 26, 2013, 04:38:05 PM »
Yea I think it was the mounts flexing too much. I took them off ant they where not torn so I welded the mount caps to the frame with chain and I have my go pedal back. Thanks for the help.
Its never ending!
Last post Apr 26, 2004, 06:31:07 PM
by 79coyotefrg
Last post Oct 02, 2006, 11:44:54 AM
by CTENG in KS
Last post Jul 28, 2012, 01:16:34 PM
by 85runner_
Last post Sep 14, 2021, 04:13:13 AM
by Gnarly4X
Last post Jan 13, 2024, 07:48:17 AM
by Rocksurfer
