I'd hafta say the motor mounts, took out your throttle cable where it passes through the firewall. Set your hand brake, have a buddy shift forward/reverse and feather the clutch and watch the engine rock. If you have a bad motor mount you can see the engine climb and twist. The throttle cable housing will crack and bind at the firewall. Last i needed one, cable is still available from Toyota dealer.
