Hello everyone,
My 1988 toyota pickup (4cyl) has been running a little rough these days. It wont go past 40mph and it backfires every now and then. It will idle just fine, but if I pop the hood and rev the engine via throttle body, it starts to choke up and wants to die.
When this problem started, I installed a new fuel filter and that didn't help. So finally the other day the truck threw a code 31 (AFM). I did a lot of research and found this write up;
http://4crawler.com/4x4/CheapTricks/AFM/index.shtml#AFMtestingand I did my AFM test using a ohm meter (first time using one) so I might need some help. I wasn't sure where to put the reading/setting at (on the ohm meter itself) x10 or x1k. So I did both hoping you guys could tell me if its messed up or not.
I followed this test (located on the link above...)
AFM Connector Pinouts:
As viewed looking at the AFM:
FC E1 E2 VB VC VS THA
Static Tests:
Table 1: 22RE (2.4L-4 cyl) - AFM Static Testing
Test Between
Terminals Resistance /
(ohms) Temperature
0.* VB - VC ~100 n/a
1. E2 - VS 20 - 400 n/a
2. E2 - VC 100 - 300 n/a
3. E2 - VB 200 - 400 n/a
4. E2 - THA 10K - 20K
4K - 7K
2K - 3K
900-1300
400 - 700 -20°C (-4°F)
+0°C (32°F)
+20°C (68°F)
+40°C (104°F)
+60°C (140°F)
5. E1 - FC Infinite/open n/a
Okay, here is my test (again, I wasn't sure what setting to put the ohm meter on (x10 or x1k) so I did both.
Terminal Resistance setting X10 setting x1k0. Vb-Vc -100 75 185
1. E2-Vs 20-400 110 190
2. E2-Vc 100-300 75 185
3. E2-Vb 200-400 45 180
4. E2-Tha 5 150
5. E1-Fc infinite/open no movement no movement
Again, I have no experience using an OHM meter, so thats why I put both of those values (two separate tests)
I'm putting my test up here because I have no clue if my AFM is good or bad. I have no idea how to read these things lol someone help please
thanks in advance
