Author Topic: 88 pickup EFI code 31  (Read 3773 times)
booger36
  • Member since Dec '12
« on: Dec 26, 2012, 08:19:11 PM »
Hello everyone,
   My 1988 toyota pickup (4cyl) has been running a little rough these days. It wont go past 40mph and it backfires every now and then. It will idle just fine, but if I pop the hood and rev the engine via throttle body, it starts to choke up and wants to die.
  When this problem started, I installed a new fuel filter and that didn't help. So finally the other day the truck threw a code 31 (AFM). I did a lot of research and found this write up;
http://4crawler.com/4x4/CheapTricks/AFM/index.shtml#AFMtesting
and I did my AFM test using a ohm meter (first time using one) so I might need some help. I wasn't sure where to put the reading/setting at (on the ohm meter itself) x10 or x1k. So I did both hoping you guys could tell me if its messed up or not.
I followed this test (located on the link above...)
AFM Connector Pinouts:
As viewed looking at the AFM:
FC   E1   E2   VB   VC   VS   THA
Static Tests:
Table 1: 22RE (2.4L-4 cyl) - AFM Static Testing
Test   Between
Terminals   Resistance /
(ohms)   Temperature
0.*   VB - VC   ~100   n/a
1.   E2 - VS   20 - 400   n/a
2.   E2 - VC   100 - 300   n/a
3.   E2 - VB   200 - 400   n/a
4.   E2 - THA   10K - 20K
4K - 7K
2K - 3K
900-1300
400 - 700   -20°C (-4°F)
+0°C (32°F)
+20°C (68°F)
+40°C (104°F)
+60°C (140°F)
5.   E1 - FC   Infinite/open   n/a
Okay, here is my test (again, I wasn't sure what setting to put the ohm meter on (x10 or x1k) so I did both.
Terminal       Resistance              setting X10            setting x1k
0. Vb-Vc                   -100                                    75                                   185
1. E2-Vs                    20-400                              110                                  190
2. E2-Vc                    100-300                            75                                     185
3. E2-Vb                    200-400                            45                                    180
4. E2-Tha                                                            5                                      150
5. E1-Fc                   infinite/open                       no movement                    no movement
Again, I have no experience using an OHM meter, so thats why I put both of those values (two separate tests)
I'm putting my test up here because I have no clue if my AFM is good or bad. I have no idea how to read these things lol someone help please
thanks in advance
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
Re: 88 pickup EFI code 31
« Reply #1 on: Dec 26, 2012, 08:44:57 PM »
x 10 is multiplied by 10 and x 1k is multiplied by 1000! Looks like you have a bad AFM, replace it!
:beerchug:
booger36 [OP]
« Reply #2 on: Dec 26, 2012, 09:27:01 PM »
:beerchug:
ohhh good to know. I assumed that those values meant 10 and 1k but I wasn't sure. So just for my curiosity, how can you tell that its bad? It's not that I don't trust you, I would just like to know how you knew that by looking at my test.  :therethere: :driving:
thanks
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #3 on: Dec 26, 2012, 11:23:50 PM »
well just take your results and do the conversion then compare those numbers to the factory specs! If they are within range then its ok, if they are out of range then its a faulty component. What kind of meter you using?
booger36 [OP]
« Reply #4 on: Dec 27, 2012, 07:18:05 PM »
This is what I was using....
PETDOC
  • Member since Jan '10
« Reply #5 on: Dec 31, 2012, 05:23:07 AM »
FWIW My '88 4Runner with the same engine as yours blew it's AFM a couple of years ago. Toyota wanted north of $800 for a new one. I got a re-manufactured AFM with a 1 year guarantee from Advanced Auto for $125 and core exchange. That was 2-3 years ago and it has worked perfectly.
booger36 [OP]
« Reply #6 on: Dec 31, 2012, 07:00:52 AM »
I went to my local autoparts store and they too wanted $800 for a AFM. I decided to check the pick and pull near my house and luckily they had one. My only problem was that the AFM was from a 22ret turbo model. So I ran to a Toyota dealer and asked if there was a difference from non turbo to turbo afm and the guy said no. Having said that, I went back to the pick and pull ans picked one up for $18.22. Works perfect and haven't had any problems.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #7 on: Dec 31, 2012, 09:49:22 AM »
Glad to hear you got it fixed!  :biggthumpup:
Last post Oct 05, 2004, 02:17:28 PM
by brainlessfool
Last post Oct 31, 2006, 11:04:24 AM
by Evrgrnmtnman
Last post Jul 11, 2007, 11:17:01 AM
by fordh8r
Last post May 08, 2009, 07:26:46 PM
by robrub00
Last post Dec 10, 2011, 08:27:02 AM
by Kourptid
