Front locker decision help?
Started by cajunboy, November 01, 2012, 04:50:17 PM
cajunboy
Im thinking about going the cheaper route and putting a spool in my front diff. Are there any downfalls to doing this. I figured if i need to unlock i can unlock a hub?
Teran H.
after the issues im having wth a lockright id go spool fml :snare:
Broken birfields could be in your future, so get some Longs with your spool. It may be cheaper initially but in the getting an air/electric locker will pay off in the long run. Personally I put an Auburn (limited slip) in my fronts and a Detroit in the rear. I have also run them front and rear with little trouble. They have a great product that lasts, cone style that never wears out.
Nimyad
Just weld it instead of wasting you money on a spool so when you decide you hate a front end that's always locked you can go buy a real locker and not lose the money a spool would have cost you.
cajunboy
Thats why I asked. Im a big fan of doing it right the first time.
Teran H.
i wouldent run welded becouse if they break apart you risk your ring&pinion  :crazy:
NorCalPR
If any locker breaks, you run the risk of busting a r/p
But welding a heat treated material makes it a lot weaker. Run a spool for strength issues
"W6FTW"
Nimyad
Quote from: Teran H. on November 01, 2012, 06:24:51 PM
If you weld it right nothing's going to break apart.
4-lo
If you plan on a full lock up front then weld the diff and invest in longs for insurance thats all I have to say.
bleakhorizon
#9
do you like to be able to turn?   then dont solidly lock the front end like a spool or welded...  i run a lockrite in the front and have never had problems... for me it slips enough to turn well and has a nice solid lockup..
i hear the aussie is even better...
Those are some huge welds!
Tillamook, OR
UndefinedTaco
I hate lockrights..aussies are good up front...air locker waste of money imo. E locker nice if you wanna mod your axle..e-locker is one of the strongest lockers you can put in a toyota axle. I wouldnt run a spool up front unless you got full hydro and you trailer your rig..you wont be able to drive it on street with a spool.
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
cajunboy
So no spool upfront.. I'm hearing some negative things about the lock rites, and sounds like the Aussie is the winner of this thread... My rig will be trailered everywhere. I don't plan on putting new longs in until I break something. It's a 85 toy axle on a 86 4runner with 5.29s and 38s. Which I figure will b putting a strain on the front drivetrain which I don't want to add to but I do need to lock up the front.
bleakhorizon
Im running an 85 with stock internals, 5.29s, and that lockrite, on 40,s and i havent broke anything (knock on wood)... just the way you wheel
Tillamook, OR
