Author Topic: engine starts but when i hit the gas it stalls  (Read 3537 times)
crazymoritz97
  • Male Posts: 298
  • Member since Jun '04
« on: Oct 27, 2012, 02:20:22 PM »
hey guys . i got a 80 with a 20r . i got it to start but it ideas for a bit then stalls or if i hit the gas it stalls . what should i like for now ?
Chris g Moritz
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
vacuum leaks, a carburetor rebuild kit....  a key to a VW scirocco
Those are some huge welds!
Tillamook, OR
crazymoritz97 [OP]
  • Male Posts: 298
okay i check the lines . i seen the choke is not staying closed . i have to pump it a few time the it will start but i hit the gas it dies . would  it help to swap the carb to a diffent carb from a diffent 20r ?
Chris g Moritz
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
Sounds like you carb has a bad accelerator pump.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
OldGold3VZE
  • Turtle Points: 4
  • Male Posts: 417
  • Member since Feb '08
  • Run whatcha brung, and have some fun!
    • Light Racing, High Performance Bump Stops
It could be a million things, well, almost.  I had a truck that did this, and after trying all the "normal" stuff, it turned out to be a severely clogged catalytic converter.  Pull the down pipe and see if it'll run, it's loud.  Remember, all you need is fresh air, fuel, spark, and a place for it all to blast out for these to run, and they're all equally important.  You've obviously got spark, air, and some dribble of fuel.  Maybe the fuel pump is on its way out?
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
crazymoritz97 [OP]
  • Male Posts: 298
chage the fuel pump then the carb to a 22r carb not a 20r carb . now it runns but at 2500 to 3000 . if i let off the gas it dies . i put a hole it filter to see that was it hasn't anything diffent
Chris g Moritz
Last post Sep 28, 2007, 01:55:41 PM
by Plekto
Last post Feb 24, 2009, 02:16:40 PM
by 83MT
Last post Sep 19, 2010, 12:16:14 PM
by twistedtoy92
Last post Aug 30, 2010, 04:00:15 PM
by crazykooter
Last post Feb 12, 2013, 10:43:15 PM
by crazymoritz97
