Axles and Motor
Started by shawn.m.carr, September 24, 2012, 08:00:59 AM
shawn.m.carr
Hey everyone I have a couple of question I have a 1986 4runner with a 4 cycle motor and wanting to drop a 350 in it i have a the motor and i am wanting to install the dana 60 axles does the axles need to be cut down or will they be direct fits?
OOPS
Depends if you want them full width where they stick out of the wheel wells or you want them mostly under the fenders. Cutting will require you to have custom made axle shafts which can be pretty pricey.
shawn.m.carr
would it be possible to make the factory axles able to hold up the the stress that the V8 would produce?
Nimyad
Depends on how you wheel. With the 60s you can just run a shallow rim and make it way narrower.
OOPS
60's in stock form are strong, but they will break. That is why there are so many up-grade parts for them.
shawn.m.carr
Well I am building a multiply purpose rig I have a small block 400 being given to me and I am wanting to do a SAS before I install the motor and transmission. But I sometimes. . . OK most of the time I have a heavy foot and I don't want to start popping Toyota shafts. But I don't want something so wide I have to watch out for little Nissan cars, and on the same note I don't want a Dana 60 that is shortened because of the price and have to have them specially cut if I broke one and possibly creeping me on the trails.
OOPS
Ford 9's are another option. Expensive to build also!!! Thing about this sport, parts cost money, upgraded parts cost more money. I am in the process of dropping about another thirteen hundred dollars into my rig in the next couple on months. You want to play, you have to pay!!!!
nisota
Just go full width its not that bad, and if you run over a little racer car then you need to pay more attention when on pavement.
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
I've seen several conversions running stock Toyota axles, they are equal to 44's. Set up with the right parts they are very strong. Running an Auto trans makes it even more forgiving.
hansi530
well u said it your self u drive with a heavy foot toy axles with a v8 and a heave fott will break all the time if i was in your position i was stay with a stock 4cyl v8s burn too much fuel
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
shawn.m.carr
I have been thinking about staying with the 4 cylinder but but i couldn't turn down the motor and well my 4runner probley actually needs a upgrade the guy that owed it before me really didn't care about it at all and i have spent the pass 2 months straightening everything out.
