Author Topic: Knuckle mount situation...  (Read 1885 times)
8Snaces
  • Turtle Points: 47
  • Male Posts: 396
  • Member since Apr '06
  • The krawler in H.H. over New Years.
« on: Sep 15, 2012, 11:31:19 AM »
I am prepping to go out wheeling ina couple weeks. i decided to go thru the front end n put in new bearing, races, seals, etc. All went smooth..took some time when it came to putting the 8 bolts into spindle and thru the large brass w/ black rubbed seal all together but otherwise all looks good. Or so i thought. The entire knuckle n hub looks correct except that the rotor is sittin about 1/2" away from the backing where as it was just slightly covered by it when i started... any idea wut i may have done to cause it?
1st gen yota truck. 37x12.5x15. 5spd dual cases, chevy springs in rear, toyota rears springs in front. Long bed....the list never ends..
Dont try to shift into 6th when u've only got a 5spd! Rubberside down doesnt always mean rite side up!
8Snaces [OP]
  • Turtle Points: 47
  • Male Posts: 396
Re: Knuckle mount situation...
« Reply #1 on: Sep 15, 2012, 03:25:57 PM »
ok..i pulled the hub n rotor all off again. checked the clearance of the bearing..it goes all the way on. pushed n rotated n pushed n rotated..its on as far as its goin. put all back together. torqued. however, the brakes wont line up squarely on the rotor now..i go to put the bolts in n its trying to turn the caliper in towards the rotor. ive checked the bolts n they r straight. would the trunion beaings play any role in alignment during reassambly @ this point? ive only torn these knuckles 2 other times n they didnt seem to give me quite this much trouble...
8Snaces [OP]
  • Turtle Points: 47
  • Male Posts: 396
« Reply #2 on: Sep 15, 2012, 03:27:46 PM »
and the rotor is still sitting out just under 1/2 ". i ordered the backing plate eliminator set the other day...
suprawheeler
  • Turtle Points: 2
  • Male Posts: 142
  • Member since Sep '08
  • Lift them...Fat chicks can't jump!
« Reply #3 on: Sep 15, 2012, 05:44:34 PM »
Trunion bearings are not your issue...which hubs and rotors are you using? Do you have pictures?
85 4Runner powered by 7mge,W56 trans,dual t-case, 5.29 gears and Toyota E-locker front and rear, Longfield 30 spline front axles and chromoly hub gears, Front Range full float rear axles, Tundra front brakes, v6 calipers and FJ60 rotors on rear, t-case e-brk, 6shooter knuckles with trunnion bearing eliminator kit, Stage 8 locking spindle nut, 41x14.50x16 Swamper Iroks.
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #4 on: Sep 15, 2012, 05:54:56 PM »
Pics are worth a 1000 words
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #5 on: Sep 15, 2012, 06:34:18 PM »
I'll bet it's the backing plate hitting.
8Snaces [OP]
  • Turtle Points: 47
  • Male Posts: 396
« Reply #6 on: Sep 15, 2012, 07:30:45 PM »
problem solved. i took it apart 3 times n realized my mistake. i put the spindle on in front of the backing plate instead of behind it against the knuckle face. all back together n rolls sweet. green sticker and a few switches n a winch n its trail time.
Last post Nov 04, 2005, 09:21:10 AM
by dj
Last post Oct 30, 2006, 10:58:22 AM
by rage
Last post May 14, 2009, 12:24:47 PM
by 79coyotefrg
Last post Dec 11, 2009, 08:40:32 PM
by *** YELLER ***
Last post Jul 19, 2015, 07:21:03 PM
by kneedownnate
