Clean 1985 Toyota Truck.
Started by koppersvette, September 09, 2012, 08:35:05 PM
koppersvette
I am selling my 1985 Toyota 4x4 pickup. The engine was rebuilt @ 4,000 miles ago. It has very little time on it basically enough to break it in. I upgraded the radiator to a thick 3 core. The truck has been my project for the last 2 years. Truck has never been wheeled with the upgrades. The springs are still settling.  The truck is sitting on 35's". the front and rear fenders are fiber glass flaired baja style.  This truck is perfect for the guy that wants to put their personal touch on it to finish it into a great wheeler.
I'm asking $6,000 OBO.
Truck is located at my Dads in Clovis, Ca.
Upgrades:
Engine, Transmission
_   Rebuilt 22R with 4,000 Miles Smogged (08/07/2012)
-   Doug Thorley header
-   Cat replaced
-   Cat back exhaust with FlowMaster Muffler
-   Thick 3-core radiator
-   Trail Gear silicone radiator hose kit.
-   180 Degree thermostat
-   Truck came with a/c but it is pulled out but have all of the parts.
-   TG HD Bomb Proof Engine mounts
-   TG HD Bomb Proof T-case mount
-   New starter
-   New alternator
-   New water pump
-   Rebuilt Carb
-   New Clutch
-   New clutch slave cylinder
-   New clutch master cylinder
-   New Heater Hoses
-   Resurfaced flywheel when engine was rebuilt.
-   3 Gages
-   Water temp
-   Oil pressure
-   Volt
-       Optima Red Top Battery
Brakes, Suspension, and Steering
Axle seals and bearings
-   Rebuilt front knuckles
-   New wheel bearings front and rear
-   Backing Plate eliminator
-   New wheel studs
-   1.5" wheel spacers front and rear.
-   TG Creeper Diff Breathers
   Brakes
-   Brake upgrades (all New Trail Gear parts)
-   IFS front calipers
   -   Vented front rotors
-   Rear disc brake conversion
-   Extended braided steel lines
-   Master cylinder
_   Vacuum booster
Suspension
Dave'z Performance Off Road
   -   Rear shock Relocate Bar
Trail Gear
-   Classic Front Lift Kit 5" springs and 5" shackles
-   Front Spring Hanger w/bolts & bushings
-   Front Leaf Springs w/bushings
-   Greasable Shackles
-   2 Bilstein Shocks 14"
-   2 Shock Hoops w/Gussets
-   U Bolt Flip Kit
-   2 Extended Front Brake Lines
-   High Steer Crossover Steering
-   Steering Stabilizer Kit
-   Heavy Duty IFS Mount Kit
-   Small Diff Armor       --Not installed still in box
-   Gusset, Upper Axle    --Not installed still in box
-   Knuckle Rebuild Kit
-   2 Wheel Bearing Kits
-   2 Bump stops      -Not Installed still in box
-   Spring Pad
-   Classic Rear Lift Kit
-   56" Long Rear Leaf Springs
      -   Welded Rear Spring Hangers
-   Rear Shackle Mounts
-   Greasable Rear 5" Shackles
-   12" Bilstein Shocks
-   Shock Mounts
-   U-Bolt Flip Kit
-   Extended Brake Line
-   Spring Perches
-   Greasable Spring Bolts & Bushings
Steering
      Trail Gear
      -   High steer kit
      -   Rebuilt IFS steering Box
      -   TG Power steering kit
         -   Pump 1450 PSI
         -   Reservoir
         -   Cooler
         -   Lines
      -   TG Steering stabilizer
Chassis, Armor
   Trail Gear
   -   ROCK DEFENSE™ FRONT FRAME REINFORCEMENT KIT
      -   Plated frame where shock hoops mounted to frame
   -   TG Power Steering Mount Plates for IFS Box
   -   ROCK DEFENSE™ Front Bumper
   -   ROCK DEFENSE™ Rear Bumper
-   2 TG Rock Lights mounted under the bed for reverse lights
-   TG license plate holder for the rear
-   TG LED turn signal kit for the front
      -   Front Bumper Winch Mount Bracket
      -   Rear Frame Support
Interior
-   Rubber bed liner painted on the floors and the back of the cab
-   Seats are out of a mid 90's Honda I think.
-   3 Gages
-   Water temp
-   Oil pressure
-   Volt
Not installed but included.
Trail Gear
-   Knuckle gusset kit
-   Magnum studs for TG Six Shooter kit
-   TG Six Shooter knuckles
-   Six shooter Steering arms
-   Six Shooter Knuckles
-   Lower Cap
-   TG Dual Transfer Case cross member
-   TG Dual Case adaptor
-   TG T-Case 4.7 with 23 spline input
-   TG HD T-Case mount
-   TG GM alternator mount
-   TG Rock Sliders
-   TG Rock Slider Gusset Kit
-   Extra TG braided brake lines front and rear
-   Front drive line (Was waiting to install the dual T- Cases before I reworked the drivelines)
-   A/C stuff
-   15" Rim un-mounted it matches the rest of the truck
-   Small Diff Armor
-   2 Bump stops
Tool Box in bed of truck not included with the truck.
koppersvette
Here are the pics.
It looks like a very clean truck, but  :yikes: that lift
Cheesemaker
Nate, I think its the fiberglass fenders that makes the lift look so big.  I would have opted for a 3" lift to keep things low, and more centered.
Good luck on the sale, it might be hard to sell a rig here that is full of TG stuff.   ;)
UndefinedTaco
Good deal for whats included...glws!
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
I thought of that, but the top of the tires are even with the bottom of the body = monstrous lift.
koppersvette
Hey guys thanks for the replies. Here are some new pics of it. It's a fun truck.
crazywb
Nice truck I'll let my cousin know, he is looking for something.
I'M BACK!!!!!!!
koppersvette
crazywb
I sent you a pm.  If you can pm me your # and I'll give it to my cousin, he would like to come check it out.
I'M BACK!!!!!!!
Mr.Kitt
Mr.Kitt
i have a 95 tacoma for trade pm if interested
koppersvette
josho
Where did you get those fiberglass sides?  Clean truck.
Holley
