Deleted
Started by clb, July 27, 2012, 08:21:58 PM
clb
Deleted
junya92toy
I have a sas, 92, and I do not run a track bar or steering stabilizer
Once you upgrade to a cross over you won't need it even on road, but they do make aftermarket bars just google it.
clb
#3
deleted
junya92toy
IFs steering box, hi steer arms and there ya go
Rockcrawlintoy
Quote from: junya92toy on July 27, 2012, 08:35:58 PM
X2 on this
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
clb
#6
deleted
junya92toy
the steering on a cross over is above the springs thats why
Rockcrawlintoy
Quote from: carlburris on July 28, 2012, 08:36:20 PM
Where is the tech link?
I don't need ....i did this.
whats the reason toyota put it there and how does crossover cure the reason????
The track bar is on there for the factory steering. I believe to keep the front axle from wraping under braking which would mess with the steering. crossover does not have that problem. Its not needed when you have high steer.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
stihlmohawk
No t-bar here and i can run 80 on the freeway no problem ... on a down hill...lol.
.....If you loose in life its because you lag.....
yotatough
Quote from: Rockcrawlintoy on July 29, 2012, 08:12:11 AM
This..... With push pull, wrap under braking will cause the truck to steer to one side without the track bar. Once you go high steer, or crossover, the slight wrap caused from braking, dose not affect steering at all. Once you go crossover, ditch the track bar completely.
