SOLD - 87 4runner, 3 link, 3rz, r151, 37's, diamond axles
Started by peacesells, May 18, 2012, 10:18:58 PM
peacesells
87 4runner base model
Drivetrain:
2002 3rz, low mileage, runs great! ORS conversion harness
marlin built r151 trans, marlin bellhousing w/very low miles
marlin 1200lb clutch, all new hydraulics
dual ultimate tcases, marlin built w/longfield output, r10 adapter, fror crossmember, marlin twin stick rear case
Axles:
Tacoma width diamond front/rear
longfields, all arp hardware, hub gears, marlin 25mm steering kit w/double sheer setup, high pinion detroit 5.29 3rd built by marlin, v6 calipers, vented rotors
Rear has alloy usa chromoly shafts, allpro disc brakes, spool 5.29 3rd built by marlin
Suspension:
4wheelundergound front 3 link kit
14in fox 2.0 remote resevoir coilovers with eibach springs fox 2.0 bumps
ruffstuff 1 3/4 heims, premium 3/4-7/8 hemis on steering/upper link
rear marlin 4in hd springs, frenched in hangers, bilstein shocks
Forged aluminum allied 17in monster beadlocks ($600 each when they were new) wrapped with 37in MTZ's at about 85%
Misc:
32 gallon custom aluminum fuel tank, carter external fuel pump
t100 booster, fj80 master cylinder, summit proportioning valve, new aisin clutch cylinder
FULL stainless steel brake lines on axles- everything is either braided stainless, or hardline
warn 9500ti w/synthetic line
full psc hydro assist kit, not installed -with pump, ram, and reservoir. Ram and resevoir have mounts installed, but rig currently has a stock pump.
Pickup tailgate
tan soft top
tig welded 1.75 .120 DOM interior cage tied into frame, body, and corbeau baja xwide tall suspension seats
crow harnesses
DOM sliders, front bumper, removable shock hoop crossmember, lots of nice fab work
Large arb compressor, switches in dash
High angle driveline front, thick-er tube rear
fully plated frame
This 4runner is very streetable- drives and handles very well. The front suspension was setup to go fast- which you can do with the 3rz
There is easily 25k in parts here, that all work beautifully together. I have invested about 200 hours into it, a fabricator friend of mine has 120 hours into it, and the previous owner (87pickup) had 200+ hours into it. Everything is built to last and be safe while doing it. All parts have very few miles ~3k. It has 2 large dent/scrapes above each rear wheel. They don't bother me, and the paint still looks good. Adds some character. Truck is not set up for emissions- no emissions equipment whatsoever. Because of this, the check engine light is on. There is 1 cat in the exhaust, but it is hollowed out.
The truck needs a lot of little things that I have not been able to get around to since I bought a house, and have another project in the garage.
By little things, I mean:
tailgate latches
Tailgate snaps for the soft top
exhaust from tcase back
harness tabs
winch hooked up
cleaning up some wiring around the battery
Realistically, these things can be finished in a weekend.
Will trade for a clean quad cab tacoma 4x4 2004 or older. TRD is a plus, and low mileage is a plus.
$10,500 with detroit front/spool rear. I will include a rear V6 ARB 5.29 marlin built 3rd for an extra $800.
See my half-assed built thread for more pictures
http://board.marlincrawler.com/index.php?topic=87095.0
this my man lysol, fresh out the joint
cen-cal crawler
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________|
86yoter
your already selling it? you just got it a month ago. nice rig though
86' runner nothing special
rocrnr
daniresch
peacesells
Quote from: 86yoter on May 22, 2012, 07:26:45 AM
I have had it for about 14 months now, only selling it since I have 2 of the same rigs
peacesells
Quote from: rocrnr on May 29, 2012, 09:43:04 PM
does it have a working ac?
No it does not, thought it could be added. I didn't see a whole lot of a point in keeping the a/c with the soft top.
peacesells
Thanks for the comments guys. sorry about the delay, I was out of town for a week. I did not mention in the original ad, this runner is not set up for an emissions controlled area. The ors harness has all of the 3rz emissions hookups, but I dont have any of them hooked up, nor do I have the equipment. The cat is in place though. Im sure it would be someone very specific who ends up buying this rig, because of the price tag, lack of emissions gear, and lack of ac. Lol
peacesells
#9
Bump. Really looking to trade for a clean low mileage 00-04 quad cab 4x4 trd tacoma. The truck has had a few parts added, now on 37in MTZ's.
jamesyz250
Nice rig. I would pick it up if it could pass smog. Good luck with the sale.
peacesells
Thanks man. It could definitely be made to pass smog, but I am not sure what it needs other than the vapor canister and a cat that actually has internals. The fuel fill is in the bed, so that is probably a no-go for California too.
peacesells
Bump, keep in mind the rig comes with a brand new PSC pump, ram, and reservoir.
pumkin toy
97 4runner Limited
hosemobile
Hypothetical stupid question.  If you ran the fuel filler to the original fuel door (of course, covering such shinanigans with the appropriate camo), would the CA
emissions folks know any better?  I hate where Toyota had to place the tank on our 1st gen. 4Runners and love what you did with yours.  Just picking your brains........
lbr50
kb2angus
I could be very interested. I am I the market for a 4runner I just sold my 72 FJ40.
location? sorry if I missed it.
Are you still holding firm on that Price?
Got any idea on how much it would take to get smog legal?
kb2angus
peacesells
Still for sale in Phoenix Az. Obviously I have not been trying very hard to sell this thing. I will sell it still, as long as it is picked up in person. The truck needs a lot of little things that I have not been able to get around to since I bought a house, and have another project in the garage. I have decided that I want to keep my front arb 3rd also.
tailgate latches
harness tabs
winch hooked up
Price will reflect work needed. Realistically, you can finish this thing in a weekend. $10,500 with detroit/spool, for $800 extra I will include an arb v6 5.29 rear built by marlin.
Shamb
Toyomatic
Is this beautiful rig still for sale. Recently wrecked my tacoma and waiting for insurance money but would defiantly be interested. Could you pm me your number
chuck85
I am possibly interested in a trade with cash on your end. I have a 2001 4 door tacoma with 96,000 miles. This truck is fully built. Sased diamond with longs, supercharged, brand new dual cases inchworm, demmello sliders, arb bumper, warn winch 9000, fox shocks all four corners. It is still on leafs. This truck is clean and one of the best daily driver wheelers I have seen. Let me know I am trying to get into a house and need some cash and would like to still have a capable rig
peacesells
This rig was sold a few months ago. Sorry about the delay, I don't get on the forums much anymore.
90 sa-yota
i know u said its sold had a question What length and weight are front springs on coil-overs? u can pm me if u want thanks
90 Yota truggy 4banger dual t-cases, front linked fj80, rear t100 axle on 39 Bfg's
DD 00 Fird f250 x-cab 7.3 auto on 33's tow rig
DD 2006 yota taco prerunner
DD 82 yota 4wd on 33's play toy
Future LONG TRAVEL toy 04 taco 4 dr. Prerunner
87pickup
If the current owner ever thinks about selling this I would be interested in buying it back.
tmoraine
acreves
bullcrew
There's plenty of time to rest when your dead or knocked out
