after the ifs box install while trying to put back the steering shaft (hysteer) 85 toy truck
we had to wedge a flat head screw driver in the small slot/opening on the "Y" u-joint looking thing to open it up a little to get the shaft to slide in
well with just my luck, the "Y" part cracked a little on top of the slot but with the bolt tightened down the crack closes up
1. do you think it would be safe still, since it is a 2pc cast together to form both sides of the "Y"
2. i looked it up at my dealership and its $200 just to replace it new but there is 4 different ones, 2 for colapsable w/ or w/o tilt
then 2 for non-colapsible w/ or w/o tilt, this sucks cause at my local Pick n Pull usually the steering column is gone so i wouldnt be able to tell if its tilt or not
any insight would help
