Thinking of hooking my base station back up
Started by unclejpl4x4, April 01, 2012, 07:53:44 AM
unclejpl4x4
I have a uniden  Washington which i have not used in yrs. I had a Antron99 with ground planekit   in a tree about 57ft up  used a man-lift and chopped off the top of the tree :shh:.
Where i live now most of the trees are 70Ft :down:  and the yard has alot  i can't ( not alowed) to use a pole off the house. Gone have to use another tree and just get it high as i can.
Now i need some advice  do to the environment I know im gonna have a high SRW  and i need help choosing a antenna i was thinking. Or if anyone has  better choices
Solarcon - IMAX-2000 - 24' Omni-Directional Fiberglass Base Station
Maco V 5/8 Ground Plane antenna
Antron99  ground plane.
I was Also thinking of moding the radio its self  I read you can add up to 18oish Chanels. I also saw a power mod which involved soldering on the board wich i can do but can't find how much power it will put out not looking for a power monster just a little bump. I already have a noise toy.  Also need a good mic The echo crapper  needs to go. any recomedations ?
the big pine behind the shed is most likely  where it will live  CB will be located in the shed
unclejpl4x4
Iv been instructed that NO  antennas  will be erected   :stopit:  :thumbdown:
fordh8r
That Uniden looks like an old President radio I have. I have 2, actually.  A Base radio with a chrome D-104 Lollipop mic and  a mobile radio in my X-tra cab.  :biggthumpup:
That sucks that you can't put up your antenna.  :thumbdown:
Cheesemaker
fordh8r
Quote from: Cheesemaker on April 03, 2012, 09:55:01 PM
Then don't make it look so obvious.  :eyebrow:
It won't be obvious until the first time he keys up and he's bleeding all over their TV's and radios in the houses!  :yupyup: :rofl2: :gap:
unclejpl4x4
the problem is theres to many trees i could hide in a few trees back but my srw and abilitys will suffer bad  and im to fat to climb up a ladder 70ft or i would :idea:  find a skinny sucker not scard of hights
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
