Author Topic: Project Undertow *2RZ Turbo Crawler*  (Read 88774 times)
Tungsten Slayer
  • Turtle Points: 89
  • Member since Aug '11
Re: Project Undertow *2RZ Turbo Crawler*
« Reply #360 on: Dec 13, 2014, 03:21:41 PM »
Yeah, 1.5" I believe from the flange and then it all goes into 1 which tapers into the turbo flange..
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #361 on: Dec 13, 2014, 03:53:59 PM »
Sure is! Nice looking manifold buddy!
Tungsten Slayer [OP]
  • Turtle Points: 89
« Reply #362 on: Dec 13, 2014, 06:31:24 PM »
Thanks man!  I have enouch pieces cut to make a few more.. Here's 2 pic's of the process.
TIG welded inside and out
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #363 on: Dec 13, 2014, 06:32:46 PM »
Very nice!!! :beerchug:
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #364 on: Dec 14, 2014, 02:42:18 PM »
very nice!
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
  • Turtle Points: 89
« Reply #365 on: Dec 15, 2014, 01:28:13 PM »
Sorry for the video quality, I was driving 1 handed and the camera doesn't pic up the audio very well, but its something until I get better footage..
MRHilux87
  • Turtle Points: -306
  • Male Posts: 424
  • Member since Apr '11
« Reply #366 on: Dec 15, 2014, 03:29:29 PM »
Sounds healthy.  I like it.  Needs a few more psi.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
  • Turtle Points: 89
« Reply #367 on: Dec 15, 2014, 04:25:40 PM »
 :think:  Intercooler and then 6 psi, that is the plan!
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #368 on: Dec 16, 2014, 01:44:02 PM »
Intercooler, little watermeth and 8-10 psi!!!  :burnout: :driving: I have a set of intercoolers off of my 05 Audi A4... I was running 22 psi no problem on them. Let me know if you'd be interested.
  • Turtle Points: 89
« Reply #369 on: Dec 16, 2014, 01:57:42 PM »
I'd take a look @ the intercoolers if you send me a pic!
Do intercoolers do that well on slow crawlers?  Should I hook up a fan for the intercooler?  Think 6-8 psi...
Seems like with hardly moving at times there wouldn't be much air flow through the cooler.  I have a trans cooler fan from an auto 4runner that would be perfect for a small intercooler if it is necessary.
« Last Edit: Dec 16, 2014, 02:21:43 PM by Tungsten Slayer »
Wainiha
  • Male Posts: 1,170
« Reply #370 on: Dec 16, 2014, 02:17:57 PM »
Sounds badass.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #371 on: Dec 16, 2014, 02:22:47 PM »
Will do! I have to head in later to pull my turbo and manifold off to weld on the tial wastegate v-band so I will swing by my storage unit and snap some pics for you.
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
« Reply #372 on: Dec 16, 2014, 09:38:30 PM »
Be interesting to see how much boost you can run before you loose throttle control and just have power and unwanted tire spin from the turbo hit. Never ran a turbo but it seems that the torque/power hits hard all at once???? I ran a big block built for low end in a wheeler and all it seemed to want to do is spin 35" tires. I think you need to be able to control it/spin. My ideal power/torque curve would be like a giant electric motor smooth and consistent at all rpm's. Seems most of the high boost RZ's are all about drag racing performance. Oh yeah forgot to mention manifold tubing parts are on the way.  :greengrin:
R.DesJardin
  • Turtle Points: 89
« Reply #373 on: Dec 16, 2014, 11:03:57 PM »
I will be really happy if I ever reach that point where it cooks the tires when I look @ the skinny peddle.  I have noticed that the boost does seem to creep up instead of just pegging out @ my wopping 4 psi.  Of course if there is a lot of load its usually full boost immediately, but it is so controllable and smooth.  Turbo size will help dictate when the power kicks in.  I went for a small turbo that spools at low rpm because it has such a small hot side.  The guys going balls to the nuts have bigger hot side probably to allow more heat and burnt air fuel volume to escape is my guess?  They probably have a higher stall converter so they would have higher rpm before a load is put on the motor causing boost to spike.. I dunno, just thinking on paper at this point.  It's fun you won't regret it, that is all you need to know right now, I'll be watching for this manifold build! :sofa:
  • Turtle Points: 89
« Reply #374 on: Dec 18, 2014, 11:39:47 AM »
Well, I am looking at buying a winch to slap on this haus.  I don't want to spend $800-1000 on a warn, so I am looking at Smittybilt and T-max right now.
The Shitty Smitty 9500# XRC 6.6hp w/ 100 ft. synthetic line weight 46lbs. and is $465 shipped to me.
The T-max is an 8500# with a 5.5 hp w/100 ft. synthetic line weight 66 lbs and is $466 shipped to me.
The smitty boasts a waterproof rating submersible up to 30 min. while the T-max says nothing of the sort.
Smitty also throws in a lifetime mechanical warranty and 3 year electrical warranty.
I've also got a very lightly used Warm M8000 I can swoop for $400 with no fairlead or line, just the winch and remote comtrol...  I am open to opinions or even story's about your brothers baby's grandkids experience...
« Last Edit: Dec 18, 2014, 12:00:06 PM by Tungsten Slayer »
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #375 on: Dec 18, 2014, 12:44:42 PM »
The Shitty Built seems like the best buy... BUT Warn is top dog....
  • Turtle Points: 89
« Reply #376 on: Dec 18, 2014, 01:18:17 PM »
I know man... I could get the warn m8000 for $400 and do the cheaper synthetic line for around $100.  The M8000 is selling for $579 new with cable and roller fairlead both of which I don't want... That is the quandry I am in, I would really prefer synthetic rope vs. cable just for the safety factor and lighter weight.
« Last Edit: Dec 18, 2014, 03:25:04 PM by Tungsten Slayer »
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #377 on: Dec 18, 2014, 03:23:00 PM »
I agree with you on the synthetic... I'll be going that route if I ever get the time to get the 4runner done... Go for the Warn if its in good shape!
MRHilux87
  • Male Posts: 424
« Reply #378 on: Dec 18, 2014, 05:31:09 PM »
I think Im gonna order a smittybuilt.  I know you usually get what you pay for... and there is a time for spending extra money, but sometimes your just paying mostly for a name.  Im hoping thats the case with winches.
I used to diss on the cheap amazon light bars and LEDs.  Then a buddy of mine got three of them, one on his rzr 800 which I borrowed.  I jumped that thing, took so many hard hits, drove it in the pouring rain for three days and it worked flawlessly.  All for 1/3 of the price of a rigid.  Hes had it for almost a year now.  No problems at all.
2013 Ninja 1000
SOLD:
  • Turtle Points: 89
« Reply #379 on: Dec 18, 2014, 05:50:03 PM »
I too have some cheap Led lights on my crawler and I like the heck outta them.  I have some experience with the smittybilt's and it was all good.  I however have a friend who has several winches and being in Oregon (where Warn is made) he has kind of talked me into buying the Warn.  He said a couple things that stand out.  He has 3 winches and the oldest and most used 1 is a Warn.  It still works great and the other 2 work, but they have become finicky.  He said he could fix them, but he can't find parts.
The Warn I am looking at was purchased new (2006), used one season on the back of a rig and then sat in the garage for 7 years.  The pics look like it is in really clean shape.  I have tried to haggle, but $400 seems to be the bottom dollar.  I think I am going to spring on it for 2 reasons.
1. The m8000 has been proven and is a solid 8,000 lbs winch which I can find parts for plus I can get the original receipt for the lifetime mechanical warranty  :yesnod::yesnod:
2. Made in USA is cool to me and I will not have to mess with cable since it has no line I can purchase my desired synthetic and not have to eat the cost of the stock line or roller fairlead which comes with the new purchase on the Smitty.
In my research I looked at the new Warn VR8000 compared to the M8000 and it's hands down the M8000 has a better motor, electronics and line speed/duty cycle.  So for about $35 more I should have a reliable long lasting recovery machine.
I bet the smittybilt would do everything I ask from it, but there is that unknown where as the Warn is already a proven good thing and is available right now to me.
  • Turtle Points: 89
« Reply #380 on: Dec 18, 2014, 05:51:27 PM »
Take that Evil Magic turtle!   All that flying around on my screen was a waste of your time.
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
« Reply #381 on: Dec 19, 2014, 06:49:11 AM »
My friend has a smittt built with syn. Line. It's always worked really well I've seen him pull a full size chev out with it didn't get hot or fry batteries or nothin. Another thing wana sell me pieces to build a manifold? Give me a price and I'm game
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • Member since Mar '13
  • @nationallmotors
« Reply #382 on: Dec 19, 2014, 08:01:45 AM »
I just got a Smittybilt XRC 12k, synthetic rope... I'll let you know how it does.
  • Turtle Points: 89
« Reply #383 on: Jan 02, 2015, 10:56:30 PM »
Tail Lights!
No moss :inthedark:
 I've had these tail lights sitting around for almost decade now... Time to $#!+ or get off the pot  :toilet2:.
« Last Edit: Jan 02, 2015, 11:49:13 PM by Tungsten Slayer »
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #384 on: Jan 03, 2015, 09:58:04 AM »
Badass!!! Looks mean!
  • Turtle Points: 89
« Reply #385 on: Jan 05, 2015, 03:01:03 PM »
Put some bed sides on and took a couple poser shots...
Just gotta get a shorter bolt and do some filing to make that mount work..hehe  :therethere:
« Last Edit: Jan 05, 2015, 11:15:08 PM by Tungsten Slayer »
Wainiha
  • Male Posts: 1,170
« Reply #386 on: Jan 06, 2015, 01:41:01 PM »
I still love the anchor panhard mount.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
MRHilux87
  • Male Posts: 424
« Reply #387 on: Jan 09, 2015, 08:24:24 AM »
If It was skinned it would take it to the next level.  Love the boatsides too.
2013 Ninja 1000
SOLD:
  • Turtle Points: 89
« Reply #388 on: Jan 09, 2015, 10:53:41 AM »
Are you spying on me? :grr:
More coming in the not so distant future  :thumbs:
  • Turtle Points: 89
« Reply #389 on: Jan 12, 2015, 06:00:26 PM »
Started on the front clip..   :flamer:
« Last Edit: Jan 13, 2015, 12:12:48 PM by Tungsten Slayer »
Last post Sep 15, 2006, 03:41:02 PM
by KWP
Last post Jan 30, 2007, 10:30:03 PM
by mudgrapler
Last post Jul 19, 2009, 09:47:52 PM
by GhostMoney
Last post Jul 17, 2013, 12:20:16 AM
by Tyler+Ashleys4runner
Last post Jan 22, 2023, 09:32:15 AM
by Nation
