if your wanting the high pinion for the rear thats no recommended as your running on the coast side of the gears in the rear sticking with the stock low pinion for rear is your strongest and safest bet, i know inchworm sells the empty housings for 250 but you will need ring and pinon for that housing tho low pinion will not work
