shackels
Started by maltby101, November 28, 2011, 05:43:43 PM
maltby101
Hey guys I got a 1984 4runner with a 4in pro comp lift and was wondering if I could put the tg rear 5" shackels on it with no modifications and will I have to do the fronts as well any help would be great
4runner UNDER CONSTRUCTION
86bobbedtoy
yeah you can put the shackles on,
might change your shackle angle if there diff lenghts
you can do either or,
good luck and welcome to marlin
maltby101
Seeings how my shackels are flatened out after 1 solid day of wheeling anything would be better thanks for the help
The biggest issue would be your pinion angles, too much of a change can cause vibration and u-joint stress, try to keep the pinion pointed straight at the rear of the trans to keep things in phase. I don't go for anymore than 1.5 lift in a shackle without further modifications. It will be even harder on the fronts over the rear since the shackle will not only push the angles down and away but will change the proper wheel alignment. Shims can correct this but is a bandaid at best.
maltby101
Oh ok makes sence so I think stocks or on there now should I just go with stocks again cause I blew out my shocks in the rear and now my rear shackels are resting on the frame so I'm just assuming I need new ones
Did they reverse or are they straight back? The shocks whouldn't cause this. Bent springs may do this. If you get new shackles go for 1 1/2 inch of lift.
maltby101
They flipped straight back they didn't reverse
How long have you had the truck or the springs? If you've had the truck and the set up a long time and it is just now doing this then something is wrong.
maltby101
I just got the truck like 5 months ago and the lift was already on it  so I have no idea how long its been on
Might be the springs are fatigued and are flattening, if the springs lose their arch they effectively become longer pushing the shackles back. This in turn will allow them to either flip or not rebound. I'd possibly consider consulting a spring shop before wasting money for nothing. They may need to be re-arched. If the springs are longer than stock this could be the reason, especially if they had to move the stock hanger locations.
maltby101
Well I want to replace them anyways so I guess this is the time thanks for all your help man
GONZO97
most likely it could be a bit of both, your springs are probably pretty old and your shocks arent helping either if they are blown, i would do a little more research before just going out and buying shackles, seems like there could be something more wrong
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
maltby101
Ya well I already have new shocks and new mounts my plan is to build this thing but my funds don't allow me to buy everything at once so most of the stuff will be replaced I just got to be able to drive it. But ya I'm looking further into it now
I've run without shocks never had an issue like this, but if they are toast then replace them anyways. Wasn't the best of ride without them, just a little bounce offroad,
maltby101
Ya well last night I went and jacked up on the rear bumper and the truck popped right back up and it has no sag  and the springs look fine not saying nothings wrong but could it be possible I came off something a little hard and binded the shackels
GONZO97
sounds like you need some bump stops, your springs probably went pretty flat shoving that shackel back and making it bind up like that, having bump stops will prevent that and also will help prolong the life of your springs
The Build:
Coming Soon
maltby101
Bump stops wouldn't be a bad idea I totally looked right past that part haha imma get some bump stops probly will help quite a bit thanks for the help
GONZO97
The Build:
Coming Soon
