ac compresser elimanater bracckket???
Started by builttoabuse, November 27, 2011, 04:48:38 PM
builttoabuse
where can i find one
toy obsessed!
blumagoo
couldn't you just take off the compressor and remove the belt?
junya92toy
No, the belt still needs to run the fluxcapacitor,
GONZO97
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
builttoabuse
hahaha. theres no belt on it right now i just need to know who sells a bracket if anyone knows a place
toy obsessed!
junya92toy
Bracket for what? if you want to get rid of it why do you need a bracket
builttoabuse
because of the power steering pump mounts to the ac compresser witch mounts to the block. the bracket mounts from powersteering to block
toy obsessed!
BigPapa
blumagoo
Snowtoy
You would be better off turning the a/c compressor into an on board air compressor, or leave it where it is at.
If I'm not mistaken the A/C compressor is on the right side and the power steering is on the left. Under the power steering is the altenator which sucks if the power steering leaks and if so equiped the smog pump sits under the A/C compressor. If there is some intermingling of brackets which there is between the power steering and the alternator then there could be slight bracket differences. That being said if there is a part of the A/C bracket (here's your hint) that has caused the power steering pump bracket to be altered A/C is an option that "SOME VEHICLES DIDN'T HAVE". Pick Your Part may have your part!
patches
I don't trust anything that bleeds for 5 days and doesn't die....
Snowtoy
Quote from: Rocksurfer on November 29, 2011, 05:11:50 AM
If I'm not mistaken the A/C compressor is on the right side and the power steering is on the left.............
For 22r(e) that is right, but he has the 3.0, w/those the PS pump is on the right side as well.
builttoabuse
Quote from: Snowtoy on November 28, 2011, 07:39:04 PM
is this hard to do? and does it work well?
toy obsessed!
86bobbedtoy
do a search on oba with ac pump
easy to do, and awesome to have on board air.
builttoabuse
Quote from: 86bobbedtoy on December 01, 2011, 09:03:47 AM
okay doing it now. dam ur runner is sick btw im doing that to my bed soon :) any tips i might need ?
toy obsessed!
