22r block ?
Started by 12 valve, October 26, 2011, 05:45:22 PM
12 valve
I have an 82 22r and just bought an 87 4runner with a bad motor. Will the 22r block work with the 22re head or is there any way to put the efi on the 22r head?
SloCrawler
I might be wrong but I think the only difference in the blocks is timeing chain tensioner
Zs Confederate Toy
The 22re head wont work. The early 22r's were short block with a tall head and the late were tall block with a short head. You will have one helluva time trying to get a timing chain to fit. You can machine the newer RE head to fit but I believe that is almost a 1/4 inch of material.
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
12 valve
Well it looks like I'm going to be rebuilding the 22re so my next question is where should I get a rebuild kit from and a good cam?
Quote from: 12 valve on October 29, 2011, 07:37:18 AM
D&J Rock is one of the best kits out there.  most machine shops can order from them and if your having machine work done you can usually order through them cheaper than anywhere else.
for a cam I would suggest http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=2B3BCB39-57B7-4E3B-9C29-71F773B35A7B
twistedtoy92
words of wisdom, dont use Rock bearings... they throw in chinese :pokinit: .... use Clevite engine bearings! I had a set crumble in less than 3000 miles....
yotaneck13
i had a set of factory toyotas berings go bad in less than 10 k.  traded motor  to 4runner he put in his 83 drove like 500 miles got a knock.  pulled pan number 2 rod bering in 4 pieces both halves snapped in half.
Quote from: twistedtoy92 on October 29, 2011, 08:48:19 PM
really?  because I just rebuilt the engine in my daughters 4runner about 2 months ago and the rock kit came with clevite bearings.  it said rock on the box but had clevite stamped in the bearing.
12 valve
Thanks for all the info I will take a look at d&j rock!
twistedtoy92
mine were in a ROCK box and when I removed them to replace they were stamped TDC on the back.... Chinese :pokinit: I had another spare set of ROCK bearings which actually had ROCK stamped on them and had no more bearing issues. Another buddy ran the same ones and got a knock after 5000 miles. replaced with Clevites and no more issues.... I will only run Clevite engine bearings
12 valve
Do you know of a rebuild kit that comes with clevite bearings?
Zs Confederate Toy
I have had Clevite bearings come in ITM kits
ZACH
87 Rock Rat X
Trail Junky
twistedtoy92
i piece all my rebuilds together now. factory toyota gaskets/oil pump/waterpump, clevite bearings, ARP studs, LCE pistons/rings/timing sets and adjustable gears. I like ROCKs head setup and then throw in a set of LCE dual valve springs and cam......
12 valve
Any ideas on a swap maybe 3rz or 3.4?
