Tony Rox is for sale.
Started by Roc Doc, October 22, 2011, 10:32:40 PM
Roc Doc
1985 Toyota SR5 xtracab.
Strong 22re with EB cam and Doug Thorley header.
V6 radiator, (NEVER gets hot).
W56 5speed and dual 2.28 cases linked with AA adapter, Bud-Built xfer case mount and HD skid plate, and All Pro disc driveline brake.
Square tube front driveshaft, rear .188 wall High Angle rear driveshaft.
Front axle is an 83 with high pinion ARB with 30spline Longfield axles and Longfield treated 5.29 Yukon gears. It also has the Sky Offroad axle widening kit (much better than using wheel spacers), hydraulic ram assist, and Marlin Crawler 25mm king pin bearing steering arms and heavy wall tie rod and drag link. Housing has been flatbottomed and hex-head machine screws installed from inside the housing (won't pull through the housing). ARP steering arm and locking hub studs.  It doesn't leak thanks to Marlins kick-ass seals, and it has HD armor over the ring gear, and HD felt/wiper plates.  There really isn't much more you can do to a Toy axle to make it better.  I figure I've got over $2500 in this axle alone.
Rear axle also has 5.29 treated gears and an Aussie locker, with Poly Performance axleshafts. There is also a Blue Devil Products anti-wrap bar, and the housing has been flatbottomed.
The flatbed is the original prototype built by Andy Widmer for All Pro Offroad, and it's welded to the frame along with a 2x2 chunk to tie the frame rails and the flatbed together in the back, along with flush mount stop/turn lights, and Hella tractor backup lights.
Front bumper is from All Pro and contains a Warn 8000 winch, more tractor lights, and swivel hoist rings for tow points.
.120 DOM tube doors by Moon Shadow Metals, and spare hard doors. .250x 2x3 rock sliders.
Alcan/Marlin springs up front and Chevy 63's out back, with Bilstein shocks at all four corners.
Wheels are 15x8" steel with HD DIY 4x4 rockrings (5) and Staun bead locks (4). Tires are well used TSL SX 38.5/14.50-15's (5).
The cab has a Smittybuilt cage, nearly new Corbeau Baja RS recliners on sliding rails (super comfortable). A two input stereo with parametric EQ and a Soundstream amp. All gauges work except the speedo, (just needs a new cable).
Hella e-code headlights, 12vGuy switch panel with interior winch control, and KC 100w offroad lights, CB radio with external speaker.
This truck has run most all of the Johnson Valley trails, the Rubicon, Moab including Prichett Canyon, the Lake Havasu trails and of course all of our local stuff. It climbs great and sidehills well for a leaf sprung truck. It starts every time, and runs like a top.
$6000 obo.
According to a recent study, 50% of all statistics are correct.
Roc Doc
Outer Limits in JV.
Roc Doc
Roc Doc
Eldorado Hills.   :greengrin:
yotajohn
Roc Doc
Guns, cash, non-SAS'd 86-88 xtracab SR5 4x4 pickup.  Just bought a buggy, so don't need another rockcrawler.
PadawanYota_Stovy
Stats : 85 Toyota 22RE , 3" body lift, 32" wild country's, Duel Marlin, Lock rights front and rear, full inside cage.
I drive , I wheel , I crawl , I am Toyota
OldGold3VZE
Bump for the Bob Marley avatar.  And truck.
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
Roc Doc
Big Pimpin!   :biggthumpup:
Roc Doc
Cole
66cobra
bad ass.... bob marley is a prophet
it's not me, it's you
Roc Doc
How about $6500?
Glory Hole
Roc Doc
Gettin close to parting it out.
Who wants what?
sckid831
how much for the switch panel?
stevesyota
84 Toyota Pickup SR5
FlexToyota
I may be interested in the real axle, PM'ed you
'84 Fugly Yota P/U
geared, locked, cases, cage, 37's, etc.
Roc Doc
Guys, I'm not to the parting out stage yet, but if I do then I'll start a thread with pricing.
Thanks.
Roc Doc
New price, $6000.
Every thing you need to build a bad ass F-Toy, SAS'd Runner or PU.
Cole
 Hi,is it registered or does it have to be towed?
Roc Doc
Quote from: Cole on January 24, 2012, 05:45:44 PM
It is registered and insured in Nevada.
90 sa-yota
90 Yota truggy 4banger dual t-cases, front linked fj80, rear t100 axle on 39 Bfg's
DD 00 Fird f250 x-cab 7.3 auto on 33's tow rig
DD 2006 yota taco prerunner
DD 82 yota 4wd on 33's play toy
Future LONG TRAVEL toy 04 taco 4 dr. Prerunner
Roc Doc
Just put in a new starter yesterday.
Bump.
Roc Doc
Sold to Brandon in Phoenix.
Enjoy!
