TURBO's L52 (rebuild in progress)
Started by TURBO, October 13, 2011, 12:11:38 AM
TURBO
#30
Next i pulled all this off
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
TURBO
 :snapshot:
I AM :screwy:!!!
TURBO
#32
Then i pulled the "Hub Sleeve No. 3" with the Shift Collar and Shift Fork all at the same time... the Thrust Washer came off with it.
I AM :screwy:!!!
TURBO
laid all of it out the way it came off
I AM :screwy:!!!
TURBO
Remove Locking Ball
I AM :screwy:!!!
TURBO
#35
next, i took off those pesky c-clips.
Then 5th gear.
I AM :screwy:!!!
TURBO
I thought 5th gear was supposed to be pressed on, but i pulled it out by hand about an 1/8th inch, and only had to lightly pry with a screw driver.
It came right off... Weird...
I AM :screwy:!!!
TURBO
what's wrong with this picture?
I AM :screwy:!!!
TURBO
removed rear bearing retainer plate.
I AM :screwy:!!!
TURBO
#39
Then I took the nose cone and snap rings off
I AM :screwy:!!!
TURBO
#40
YOU MUST REMOVE THE INNER C-CLIPS
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
TURBO
#42
Ok, Next we have to pull the counter shaft bearings so we can get the counter shaft to "drop" out of the way'
there are two types of pullers that will work for this. I prefer the dedicated type over the 3 jaw locking type.
I borrowed the ones on the right from a super good friend of mine,
the ones on the right are available here:
http://www.shoptoolsshoptools.com/shopexd.asp?id=1160
http://www.shoptoolsshoptools.com/shopexd.asp?id=1159
I AM :screwy:!!!
TURBO
#43
umm... oops lol
I AM :screwy:!!!
TURBO
#44
then i pulled the front counter shaft bearing
I AM :screwy:!!!
TURBO
#45
then the rear counter shaft bearing
(you can pull it out now or wait till you get the rear main shaft bearing off either way will work.)
I AM :screwy:!!!
TURBO
then i pulled the rear main shaft bearing
I AM :screwy:!!!
TURBO
#47
Now that the counter shaft has "dropped" out of the way the input can be removed.
I AM :screwy:!!!
TURBO
There are fourteen (14) 5.5mm rollers inside the back of the input... make sure you don't lose any
I AM :screwy:!!!
TURBO
Pull the gear set...
I AM :screwy:!!!
TURBO
Counter shaft...   :qtip:
I AM :screwy:!!!
TURBO
Then i started taking the gear set apart
I AM :screwy:!!!
TURBO
 :snapshot:
I AM :screwy:!!!
TURBO
i bought this bearing separator from Harbor Freight, it's not bad... got the job done.
http://www.harborfreight.com/large-bearing-separator-3979.html
-$24.99
I AM :screwy:!!!
TURBO
#54
I placed the bearing separator flat side up, right up against the teeth of 2nd gear, and just snugged up the bolts on the bearing separator by hand.
Then I pressed the hub off
just make sure you hold the main shaft so it don't smash a hole in your floor
I AM :screwy:!!!
TURBO
then I flipped the shaft over and did the same thing to 3rd gear
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
TURBO
#57
:snapshot: 1st gear
I AM :screwy:!!!
TURBO
#58
:snapshot: 2nd gear (and reverse)
and 1st / 2nd shift hub
I AM :screwy:!!!
TURBO
:snapshot: 3rd gear
(and 3rd / 4th shift hub)
I AM :screwy:!!!
