TURBO's L52 (rebuild in progress)
Started by TURBO, October 13, 2011, 12:11:38 AM
TURBO
#60
then I pressed the input (or front main shaft) bearing off
(flat side of bearing separator towards bearing)
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
TURBO
#61
the "gear spline" pieces can be pressed off,  so as to clean the splines between them... but that bearing splitter i bought wont work to get all of them off unless I grind it, and I figure since it's not like I waisted the counter shaft or anything it's not like there was a lot of metal flowing threw the oil, Figure I will just give it a good wash in some cleaner and call this part of the job good.
I AM :screwy:!!!
TURBO
#62
remove 5th gear detent ball and spring,
punch out roll pin
pull 5th gear shift rod
I AM :screwy:!!!
TURBO
#63
 :snapshot:
I used the same 3/16 inch pin punch as before
I AM :screwy:!!!
TURBO
Remove the 12mm bolt holding the reverse idler shaft's locking tab.
Slide the idler shaft out and catch the reverse idler gear.
I AM :screwy:!!!
TURBO
next thing i did was remove the reverse idler linkage
I AM :screwy:!!!
TURBO
Next thing I did was start taking apart the top cover... this should almost be it's own section but... it's not that bad
I AM :screwy:!!!
TURBO
#67
I started with this 17mm bolt, and started taking apart all the detents, and interlock pins out
This detent is actually the detent for 3rd/4th gears
I AM :screwy:!!!
TURBO
broken spring  :thumbdown:
I AM :screwy:!!!
TURBO
next is the 9.5mm (0.375") detent ball
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
TURBO
Next thing I did was knock out the freeze plug using a dead blow hammer on the 3rd / 4th shift fork
I AM :screwy:!!!
TURBO
#72
Then I punched out the roll pin and removed 3rd/4th shift fork
I AM :screwy:!!!
TURBO
Thee elusive interlock pin...
I AM :screwy:!!!
TURBO
....watch as she stalks her prey...
I AM :screwy:!!!
TURBO
Kroikie!!! that tarp never stood a chance!!!
I AM :screwy:!!!
TURBO
#76
Next thing to come out is the 1st/2nd shift rod and fork
so I drove out the roll pin for the shift block, and used the shift fork to hammer out the next freeze plug
I AM :screwy:!!!
toyotech
#77
TURBO
 :eye: :eye:
DON'T LOSE THIS PIECE!!!
I AM :screwy:!!!
TURBO
then i slid the shift rod back in it's home so i could remove the shift fork's roll pin and not put any weird stresses on the aluminum housing...
I AM :screwy:!!!
TURBO
remove shift fork and shift block
I AM :screwy:!!!
TURBO
the detent for 1st/2nd sits above the shift rail when it's installed in the truck
I AM :screwy:!!!
TURBO
#82
'Nother broken spring  :thumbdown:
then take out the interlock pin
I AM :screwy:!!!
TURBO
#83
then i took off the Reverse "E" clip,
and pounded out the freeze plug
I AM :screwy:!!!
TURBO
the reverse light switch stops you from putting the reverse gear shift rod all the way back in it's home to pound out the roll pin...
either take it out with a wrench or leave it...
i just left it
I AM :screwy:!!!
TURBO
:snapshot:
I AM :screwy:!!!
TURBO
I magnetized my 3/16" pin punch and extracted the Reverse detent ball
had to also use a hook to get the spring out
I AM :screwy:!!!
TURBO
#87
next is to take off the 5th gear "E" clip
and then the 5th gear connector piece
I AM :screwy:!!!
TURBO
it was kinda awkward to punch 5th gear freeze plug out so i did it like this... probably not the best way, but it worked
I AM :screwy:!!!
TURBO
remove 5th / reverse shift block
I AM :screwy:!!!
