TURBO's L52 (rebuild in progress)
Started by TURBO, October 13, 2011, 12:11:38 AM
TURBO
in with the stock spring for 5th gear!
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
TURBO
then the 9.5mm (0.375") detent ball
I AM :screwy:!!!
TURBO
time to install 5th gear (upper) shift rod
I AM :screwy:!!!
toe
Me
TURBO
#124
am i do'n ok so far toe?
...angled side first
I AM :screwy:!!!
TURBO
PAUSE
right here for a moment and
lets get 5th/rev shift block ready
I AM :screwy:!!!
TURBO
install the interlock pin in the 5th/rev shift block
I AM :screwy:!!!
TURBO
#127
you might have to use a punch or something just to push the shift rod in until the detent ball clicks into place
I AM :screwy:!!!
TURBO
next thing i did was put the roll pin in the 5th gear conector-ma-bobber
I AM :screwy:!!!
TURBO
then i moved the 5th/rev shift block into a position so that when i hammered the roll pin home the interlock pin wouldn't fall out
I AM :screwy:!!!
TURBO
then i installed the 5th gear conector-ma-bobber
I AM :screwy:!!!
TURBO
then i put the 5th gear e-clip in place
I AM :screwy:!!!
TURBO
#132
then it's time for another interlock pin
I AM :screwy:!!!
TURBO
make sure the interlock pin is still in the 5th/rev shift block, and that it is out of the way of the shift rail that's gonna need to go threw there
I AM :screwy:!!!
TURBO
note how the shift block is up against the e-clip
I AM :screwy:!!!
TURBO
reverse shift rod
I AM :screwy:!!!
TURBO
:snapshot:
I AM :screwy:!!!
TURBO
#137
i use the angled face to help push down the detent ball
I AM :screwy:!!!
TURBO
#138
install roll pin in reverse-hangger-ba-janger
I AM :screwy:!!!
TURBO
now here's a tricky part... sense i left the reverse light switch in, i had to use the "ramp" to press the switch down, then i flipped the shift rod 180 degrees into it's 'normal' position
1st: put angled side towards switch
I AM :screwy:!!!
TURBO
#140
2nd: install interlock pin
I AM :screwy:!!!
TURBO
now push the shift rod all the way in
I AM :screwy:!!!
TURBO
#142
now turn the shift rod over
I AM :screwy:!!!
TURBO
then i put the roll pin threw the rod
I AM :screwy:!!!
TURBO
next is the Reverse e-clip
I AM :screwy:!!!
TURBO
next goes the big interlock pin
I AM :screwy:!!!
TURBO
heres where I but the first HD spring...
I AM :screwy:!!!
TURBO
then I put in the 1st/2nd shift rod
I AM :screwy:!!!
TURBO
interlock pin
I AM :screwy:!!!
TURBO
shift block and fork
I AM :screwy:!!!
