Author Topic: 22re timing chain  (Read 2081 times)
puunui
  • Male Posts: 35
  • Member since Mar '08
22re timing chain
« on: Oct 10, 2011, 05:38:54 PM »
having hard time taking off bolt on the crank pulley. I tried using the starter to remove the bolt. Anymore suggestions? thanks
Richmondo
  • Turtle Points: -1
  • Member since Jun '08
Re: 22re timing chain
« Reply #1 on: Oct 10, 2011, 07:19:25 PM »
Chain wrench, big 1/2" breaker bar, cheater pipe, some penetrating lubricant and a couple of buddies?  I've always been apprehensive about the starter motor trick but when I did resort to it it always worked
It was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #2 on: Oct 10, 2011, 07:26:30 PM »
I usually use an impact
88 Pickup SAS'd, 3.4 V6, R151F Hybrid, Dual Ultimate, Triple sticks, 35's, 5.29's, HP front, V6 rear, Aussies, 63" Chevs, Anti Wrap Bar, Warn 8274 on Home Built Bumper
4WU linked 86 Xtra Cab build in progress
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #3 on: Oct 10, 2011, 07:27:52 PM »
Tranny in 5th, parking brake on to lock up engine.
Pipe on wrench (or breaker bar), sit down on ground and push with leg.
skylinetoy
  • Turtle Points: -1
  • Male Posts: 16
  • Member since May '06
« Reply #4 on: Oct 11, 2011, 06:31:53 PM »
Have had to use a torch and heat the bolt and then impact it off. Most of the time just an impact works though.
85 Extracab, 3RZ, 35's, bobbed
83 w/3RZ on 39.5's in the works
Yota87Truck
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
« Reply #5 on: Oct 11, 2011, 09:03:55 PM »
First time I pulled the pully I don't remember having a problem and I didn't have an impact gun at the time.  I must have used a cheater pipe or something.  But the past 2x I have done it I have had to torch it and impact it off.
« Reply #6 on: Oct 11, 2011, 10:00:13 PM »
if the idiot before you used red loctite then you will need a torch.
a half inch breaker bare up against the frame (pass side) always worked for me, well besides that one time :aaa:
ascdub
  • Turtle Points: 32
  • Male Posts: 41
  • Member since Nov '08
« Reply #7 on: Oct 12, 2011, 12:40:24 AM »
I had to drop the oil pan and  wedge ascrew driver between the block and crank andused a braker bar and the pipe from my floor jack. The e brake trick didnt work for me.
  • Male Posts: 3,561
    • emsvitil's album
« Reply #8 on: Oct 12, 2011, 12:44:26 AM »
Need to be 5th with the ebrake.
4wd hi and bricks at the tires will help if the ebrake doesn't do it.
Last post Jul 09, 2006, 04:11:28 PM
by jimbo74
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Jul 09, 2009, 12:04:56 PM
by basser530
Last post Feb 22, 2012, 08:29:11 PM
by daniresch
Last post Oct 01, 2019, 10:27:19 AM
by Danieldotcom
