play in rear transfercase
Started by ozyota, October 10, 2011, 02:40:12 AM
ozyota
Have some up and down movement in the rear output flange on my '83.
The flange is tight, the bearings are good and i even swapped the rear cover / housing on the back of the transfercase.
The movement is still there and the seal is starting to leak :help:
Any ideas??
Thanks Matt
crazykooter
Most have some up and down movement.  The pocket where the bearing sits stretches a little.
A lot of the time if your leaking you can put a marlin hd seal in and it will be fine.
ozyota
Do you mean where the rear bearing sits in the housing? ( pocket )
Will check out all of my spare cases and see if i have a good one :crossed:
Then i will see if Marlin will post to Australia, last time i emailed i got no reply.
Thanks for the advice.
Matt
crazykooter
They will send to Australia.  Ive seen dual case adapters and what not sent there.
