Custom rear interior side panel ideas please!!!
Started by zj4runner, September 28, 2011, 08:35:32 PM
zj4runner
Just need some ideas on makeing my own rear interior side panels. Please, im trying to make my runner shine!!!
toyotech
zj4runner
Ive thought about that, would be cool. Looking for something a little cheaper and easier to make. I will buy 1st gen 4runner panels if they are in good condition. Thanks
blackdiamond
zj4runner
bleakhorizon
I made fiber board sides... coated them in fiberglass resin to keep em water tight..
then wraped them in vinyle and used self tapping screws to attach them..  Unfortunitly i didnt get pictures of the finished product
Those are some huge welds!
Tillamook, OR
zj4runner
zj4runner
bleakhorizon
The fiberboard was acquired at a local lumberyard (same stuff as speaker boxes are made from)..  Vinyl i got from a "craft" type store.  fabric store, upholstery shop, whatever....
I cut out the pattern then proceeded to coat the inside and out of the wood with fiberglass resin, (im sure there is something else you can use that might be easier and faster but thats what i had) this made it water tight...
Took the vinyl layed it over the wood and cut it so i could wrap it over the edges, sprayed some 3m headliner type glue on both the vinyl and the wood and pressed them together... after they set up a bit i wrapped the vinyl around the corners and stapled it to the back of the wood. this gave it a nice tight finish.  Then i cut reliefs into it so i could have holes for my speakers and access for my jack and storage area..
Got some not so great pictures today (was to dark to see most details) but these are as it sits..
dirty and covered in mud because of my lack of inner fenders....YES lol. but they do there job, they look pretty :)
I dont have the doors on them anymore mainly because they were just getting in the way trying to open them... i used kitchen cabinet hinges that were hidden on the inside and the doors opened out.
sorta like these
Tillamook, OR
zj4runner
I gotta say, thats pretty sweet. Thanks for taking the time to send me some pictures, it helped alot. Thanks. Ill post some pics when i get my interior done.
Buck87
I wonder if aluminum would rattle and be cold.
Matt 1987 4Runner, 5speed, 22re,SR5, mostly stock
grantxurismo
i used a sheet of textured ABS plastic to make new door panels, and held them in with late model GM inner fender retainers
turned out awesome imo
:beerchug:
toyotech
i been looking for some ABS plastic. where did you get them and are they expensive?
toyotech
dont have a lowes here, just Home Depot for a big home center. and lots of auto parts places.
toyotech
for sure most auto parts stores carries alot of GM clips
Snowtoy
Quote from: Buck87 on December 13, 2011, 09:09:12 PM
It shouldn't rattle if you use screws and some adhesive.  As for being cold, the oem panels don't offer much in the way of insulation as it is.  In the ones I have restored I have stuffed some foam or fiberglass insulation(paper side out or in garbage bags) between the two panels. I didn't keep the Runners long enough to see how the insulation worked, though it did quiet down the road noise quite a bit.
grantxurismo
Quote from: THK Matt on December 21, 2011, 04:10:57 PM
P/N on the GM retainers?
i can check later in the week
Quote from: toyotech on December 20, 2011, 10:51:16 PM
bought a sheet and made them myself
sorry for the reply a year later
:sleeping:
:beerwhack:
GRW
Were did you get the Sheet at?
I have looked at around and made some calls and have not had much luck so far.
Thanks
84 XTRA CAB 3RZ
01 Tundra for sale
11 TDI Sportwagon
http://www.supermotors.org/vehicles/registry/showmedia.php?id=274806
ringwraith
Stumbled across this and thought I'd add a pic of the aluminum panels I made in case other people come across this thread.  Was pretty easy to make, just traced the old cracked panels onto the aluminum and cut them with an electric shear.
