Sway bar link removal
Started by builttoabuse, September 26, 2011, 06:24:53 PM
builttoabuse
 :welcome: how many people have done this and are running there trucks with out them?   everyone has there own opion i know i just wanna see. Sway bar link removal
toy obsessed!
Trash it, one of the 1st things I do to improve travel.
4RunnerChevy
When my truck was IFS, I made fancy quick disconnects.  Disconnected it once, to go on a trail, never got reconnected, finally ended in the trash.  I saw no real difference running without it on the road.
builttoabuse
same thing here i love it without  8)
toy obsessed!
2manytoys
You won't get more travel with IFS but, it sure rides nicer without it. Chucked mine a long time ago. No regrets.
rattlers
do you think if i remove mine on my stock 85 4runner it will ride nicer.
__________________________
ll_______ll_______ll__TOYOTA_ll
ll_______ll_______ll____85____l
4RunnerChevy
Quote from: rattlers on September 27, 2011, 05:10:07 PM
Yes
builttoabuse
toy obsessed!
Quote from: 2manytoys on September 27, 2011, 04:11:55 PM
True that it doesn't give any more than the bumpstops will allow but the freedom does allow for true independent travel. With the swaybar on the travel is greatly restricted. Want more travel you either need to shave the stops or get some flat ones.
Sparkplug
No one else notices different handling when the sway bar is removed? I remove it also, but it seems to dip the front inside tire more in turns after that. Maybe its just me?
rattlers
Quote from: Sparkplug on September 28, 2011, 08:46:02 AM
did you notice if it gives a better ride on the street with the sway bar removed, I was going to remove mine on my 85 4runner, oh did you take it off a sfa truck
It won't change the ride but will free up the travel and that's why you may feel the "dipping" you are referring to.
Tofudude
the body will lean further out causing that "dipping". The ride quality only affects the IFS system
Goldrush
I took mine off my 4runner. ran it for a year or two without it. did ok, but had alot of body roll, and i have a locker in the rear so it made it worse. so i put it back on and i like it way better than having it off.
rattlers
Quote from: Goldrush on September 30, 2011, 09:29:54 AM
do you have ifs or sfa
Goldrush
I meant the sway bar in the rear. I have Ifs. I thought u meant rear sway bar. Lol my bad
86RTEC
Do you want to wheel it or carve turns on a paved road? Wheel=no sway bar, carved turns= bar.
To the moon!
Tofudude
yeah, that truck stock drives like a car on the road. Even after you ditch it though its still pretty good
