knuckle rebuild kit grease?
Started by yotacrawler1, September 23, 2011, 04:16:51 AM
yotacrawler1
hey guys i just got my knuckle rebuild kit in today. hopefully itll stop that leaking hahahah. but was wondering what grease and how many tubes of it should i buy tomorrow?
crazy white boy
i always use marine grease. 2 tubes should do it and then some
Joshua 1:9
yotacrawler1
Wermz84
FSM calls for "Molybdenum Disulphide" lithium base grease inside the knuckles.  Marine will work as well.  Just never mix greases with different bases and you should be good.
I would also recommend making sure your knuckle is centered on the housing, to prevent it from possibly leaking again. Not saying that is why it is now, but while it's apart it is good to check.
I like to Drive!
yotacrawler1
yeah i just bought napa's 6lb tub. was only around 15 bucks. than il have a hell of a lot extra for whatever
86RTEC
.040 shims on the bottom to get the axle shaft centered, then adj the top shim pac as nesc. to get the right preload on the knuckles.  more preload than stock is better for taller tires and will cut down death wobble, measure the preload with the wiper seals out. marine grease for sure.
To the moon!
yotaneck13
you could always try this stuff
http://board.marlincrawler.com/index.php?topic=81098.0
i actually got him to send me some to test out and it is just gear oil with some grease mixd in
RNR FABRICATION ON THE EAST COAST!!! [email protected] (814)-516-5176 like us on facebook www.facebook.com/rnrfab
Quote from: 86bobbedtoy on May 10, 2011, 08:42:59 PM
86bobbedtoy
Quote from: yotaneck13 on November 05, 2011, 05:59:11 PM
haha that thread was funny.
i actully looked forward to gettin his panties in a bunch
yotaneck13
SloCrawler
I tapped the feeler hole on the knuckles and put grease fitting,  I pumped 1.5 tubes of grease in each side probly can take more.
yotaneck13
Quote from: SloCrawler on November 05, 2011, 11:00:28 PM
thats a good idea but do you assemble dry or put some in before you assmlble?
SloCrawler
Quote from: yotaneck13 on November 06, 2011, 04:19:17 AM
they had oil originally at rebuild.  Drained through a stud and pumped full of grease.
ky-homelite
Quote from: SloCrawler on November 06, 2011, 02:24:37 PM
That's a pretty slick idea!
sparkys83yota
Quote from: Toynoter on December 30, 2011, 10:42:38 PM
The type of grease .
Oh boy, well There is a semi fluid grease used by the manufactures of these axles
seriously toynoter. When i first started playing with toyotas i relied on the information from this website to learn what i was doing. No body fed me a line of bs so why dont you leave that crap for your bacon thread and let the new guys learn from people who actually know what they are talking about. Sorry if this is thread jacking but this guy is rediculous.
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
yotaneck13
yes you are correct he is rediculous
86bobbedtoy
yep its our big coinsiracy against YOU!!
and anyone trying to put goop in axles
yotaneck13
i did test it last weekend put it in one side and grease ive used for years in the other guess which axel broke.  YOU OWE ME A LONGFIELD
Crawlin85
x2 on the marine grease, i do alot of river crossings so i just put it in everything that has a zert fitting or needs grease. been running it 3 years no problems.
i think threads on what type of grease to run should be banned just so this guy has nothing to talk about or try to sell
85 runner with cool stuff
-A truck with a body lift is like a fat girl in a mini skirt, it shows you everything you don't want to see
86bobbedtoy
hah or only be able to post in them if you have been a member for so long or have xx amount of posts
