Poll
I bought a truck and somebody put the timing chain on wrong with the cam gear off 180 degrees from the crank.  What should I do?
The valves are bent, pull head fix
3 (23.1%)
valves are fine, fix timing chain
3 (23.1%)
valves may/may not be fine, fix timing chain and see
3 (23.1%)
valves may/may not be fine, pull head and fix everything
4 (30.8%)
Total Members Voted: 13
Author Topic: 22R motor problems  (Read 8721 times)
Yota87Truck
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
22R motor problems
« on: Sep 01, 2011, 09:30:23 PM »
 :headscratch:
1980yota
  • Turtle Points: -2
  • Member since Jan '11
Re: 22R motor problems
« Reply #1 on: Sep 02, 2011, 06:00:58 AM »
The 22r is an interference engine. There could be damage to the valves. Pull the timing cover and put the chain on correctly, set the distributor about 8-10 degrees advance and try to start it. If your missing on one or multiple cylinders or if it wont start then its time to pull the head.
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
« Reply #2 on: Sep 02, 2011, 06:43:06 AM »
X2 very easy fix if valves are still good.
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #3 on: Sep 02, 2011, 07:09:27 PM »
anybody else have this problem?  or know somebody who accidentally put timing chain on wrong and put it all back together and tried to crank it over.  Any actual experiences?  I plan to do the timing chain first.  Less $$
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #4 on: Sep 02, 2011, 10:18:51 PM »
A bent valve can do piston damage, so it would be worth pulling the head and checking the valves just to avoid compounding the problem.  A full gasket kit from enginebuilder.com is less than $70, a lot cheaper than having to replace a piston.
1980yota
  • Turtle Points: -2
« Reply #5 on: Sep 05, 2011, 07:23:29 AM »
If the valve is already bent it has already done all the piston damage its going to do. It could do damage to the head but just a quick crank will tell if there is valve trouble or not. I think its worth a shot to try the timing chain first not only to save money but to save time.
« Reply #6 on: Sep 06, 2011, 02:44:12 PM »
put the timing chain on correctly and set the timing CORRECTLY then run a compression test.  chances are very good that you have at least one bent valve but the compression test will show if they were bent bad enough to warrant pulling the head off.
if it was a perfect 180* out then the valves shouldnt have made contact since the valves would be opening  on the compression stroke and closing on the exhaust stroke. 10 degrees off and the motor would have had serious binding issues and if rotated with the starter valves would be bent badly.
fix the chain, run compression.  if you post and I dont reply that day send me a pm.
DONT FORGET the 8m bolt (12mm head) under the distributor drive gear. its in that pool of oil the gear rids in.
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #7 on: Sep 06, 2011, 06:32:03 PM »
Well the progress is slow.  I am just taking my time on it.  I plan to fix the timing chain and see how things look from there. (compression test, etc...)  what numbers should I expect for bent/non bent valve?
« Reply #8 on: Oct 01, 2011, 12:55:21 PM »
bent valve  look for anything under 50 psi
for non bent 100 psi to 140, if the rings arent good,  150-180 for good rings
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #9 on: Oct 09, 2011, 09:03:19 PM »
So as I am doing the tear down(I know I have been really slow) I am wondering how the timing chain got to be 180 degrees off.  The information I have collected leads me to believe that this motor has 100k miles. The oil/crud on this motor during tear down looks like it hasn't been tore into at all recently.  The only thing that looks new is the carb (possible recent rebuild).
Anybody know how a motor could become exactly 180 degrees off with out the removal of the timing/front cover?
Snowtoy
  • Male Posts: 2,583
« Reply #10 on: Oct 09, 2011, 09:32:22 PM »
If the PO didn't know what he was doing, and only went by the timing marks, the engine could have been 180* out when he removed the old t-chain.
The appearance of not being opened up doesn't necessarily mean it hasn't been, not everyone will clean engine components before rebuilding it, especially if they are in a hurry.
« Last Edit: Oct 11, 2011, 08:07:19 PM by Snowtoy »
Richmondo
  • Turtle Points: -1
  • Member since Jun '08
« Reply #11 on: Oct 10, 2011, 07:39:51 PM »
Could have pulled the head or the cam with the crank 360 degrees out but went back in with the cam in the correct position for TDC. That's about the only explanation I could come up with...
It was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
skylinetoy
  • Turtle Points: -1
  • Male Posts: 16
  • Member since May '06
« Reply #12 on: Oct 11, 2011, 07:30:03 PM »
With my experience with this kit everything is good except the headgaskets. I have used a couple myself and have several buddies who have also. Six months to a year and the gasket will blow. I usually use everything else and buy a good felpro head gasket.
85 Extracab, 3RZ, 35's, bobbed
83 w/3RZ on 39.5's in the works
« Reply #13 on: Oct 11, 2011, 09:53:35 PM »
:rofl:
Felpro??   :haha:  OMG NO,   get a Toyota head gasket from the dealer of D&J Rock
TURBO
  • Turbo Extremist
  • Turtle Points: 65475
  • Male Posts: 706
  • Capt. Insaino shows no mercy
« Reply #14 on: Oct 12, 2011, 08:18:40 AM »
x2 on the Toyota head gasket, no reason to go cheep on a head gasket
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #15 on: Oct 12, 2011, 10:41:47 PM »
For Sure.  I like buying parts directly from the dealer, depending on how much they want compared to Autozone/Checker/Napa, etc.
« Reply #16 on: Oct 13, 2011, 09:43:06 PM »
they dont sell a headgasket of a quality that you can depend on. I'm SERIOUS. Ive done this 100 times.   Napa used to sell Victor gaskets and they were OK, but nothing compared to DJ Rock (what engnbldr sells) or the Toyota factory (you buy from a toyota dealer parts department) gasket.
Mega Baby Huey
  • Turtle Points: 36
  • Male Posts: 432
  • Member since Jan '07
  • Do It!
« Reply #17 on: Oct 13, 2011, 10:32:13 PM »
when you tearing into it? I'm probably going to come down to get a new rear window for my 4runner (did i tell you i shattered it?) and i'd love to tear into a motor while i'm down there!
The Art of Flying is Actually Quite Simple! You Just Have to Throw Yourself at the Ground and Miss!!!                                   All This Global Warming is Wearing Out My Snow Shovel!!!                        Paved Roads: Just Another Example of Useless Government Spending!                                          Toyota. Moving forward... even if you don't want to...
My Old Toy
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #18 on: Oct 13, 2011, 10:38:04 PM »
I have all the accessories removed.  I just need to drop the oil pan and pull the front cover off now.  I haven't had much time to mess with it but this one is stuck on pretty good compared to previous front covers I have pulled.
skylinetoy
  • Turtle Points: -1
  • Male Posts: 16
« Reply #19 on: Oct 16, 2011, 06:27:45 PM »
Do what you would like. Just putting my  :twocents: in. I have never had a problem with Felpro and ran them on my race motors for years also. I have blown 2 Rock gaskets myself and know of about 5 others that have. Toyota is definitely your best option if you want to spend the change though
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #20 on: Oct 16, 2011, 06:44:33 PM »
The toyota vs felpro gasket debate is stupid. I use felpro all the time, they work fine. Ive used over 10, and none have blown that I know of yet. Only time ive ever had a hg fail was a rock gasket matter of fact, but it was also the only time we didnt surface the head, and it had kinda corroded jackets so that could have been it.
There are 2 dif fel pros I know of for 22r. One is the kind that seals and kinda sticks to the block and head, its silverish flaky material,the other is almost an exact copy of the toyota one. Both work fine.
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #21 on: Oct 17, 2011, 09:29:50 AM »
The graphite ones you speak of are the ones that've had all the issues over the years (and yes, it's been well documented), and the ones that look like a toyota gasket are the ones they developed after they removed their heads from their asses  :thumbs:
« Reply #22 on: Oct 17, 2011, 04:10:39 PM »
:shake:   cant blame it on the headgasket then.
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
« Reply #23 on: Oct 17, 2011, 11:24:04 PM »
I have had several head gasket problems in the past (both jobs I have done and had a shop do)  I'm not sure what gaskets were used but I think another issue is the head bolts.  I never replaced the head bolts with new ones or studs and I don't know what the shops I went to did either.
« Reply #24 on: Oct 18, 2011, 12:20:14 PM »
make sure the head bolt holes are clean and no trash in the bottoms and you should be fine.  I am still using the 20R headbolts that came with my truck and thats been about 5 headgaskets ago.
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Get Some
« Reply #25 on: Oct 24, 2011, 01:52:52 PM »
Ide take the valve cover off, take the cap off , look at the rotor ,
Then look for the . On the cam gear!!
If you don't have a super loose rocker , probably fine imop,
50/ 50 chance
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #26 on: Oct 29, 2011, 08:11:00 PM »
ARP head studs, good surface on block deck and head deck with a factory Toyota HG, clean and proper torque... you will not have an issue!
Last post Aug 05, 2004, 10:45:58 PM
by WHITE_TRASH
Last post Jun 03, 2007, 11:33:49 AM
by RN37DD
Last post Sep 13, 2007, 06:27:05 AM
by 89toy
Last post Sep 12, 2008, 07:53:33 PM
by jimbo74
Last post Apr 25, 2010, 12:47:04 AM
by havik
