Author Topic: step by step?  (Read 4201 times)
jsimp
  • Turtle Points: 2
  • Male Posts: 111
  • Member since Jan '11
step by step?
« on: Aug 14, 2011, 05:39:19 PM »
hey, i was wondering if someone, some people, could write me up some instructions or something do do chevy 63's and RUF, i wanna get about 5 inches of lift, and i dont really want to do the ifs stearing box, so is there another way to do my stearing? please and thank you
85 ex cab, 31s, 22r pretty much bone stock.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: step by step?
« Reply #1 on: Aug 14, 2011, 07:30:21 PM »
Dropped drag link, but if you are going to wheel it on rocks, bring spare "J" arms with you. Good luck on getting 5" lift with RUF's and Chevys.
You should also do this to the "J" arm's.
http://board.marlincrawler.com/index.php?topic=33240.0
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: step by step?
« Reply #2 on: Aug 14, 2011, 11:45:01 PM »
hysteer is one of the best upgrades though..... honestly
1980yota
  • Turtle Points: -2
Re: step by step?
« Reply #3 on: Aug 15, 2011, 10:22:50 AM »
I only got about 3 inches out of my chevy and ruf setup. If you want 5 your going to have to use some lift springs mixed in or something.
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #4 on: Aug 15, 2011, 10:39:56 AM »
i wont be running on rocks, theres not to many around where i live :( haha
OOPS
  • Male Posts: 2,561
Re: step by step?
« Reply #5 on: Aug 15, 2011, 11:34:21 AM »
You can get away with the push-pull steering, a lot of people did when Toyota's first came out with the 4x4's. But you also need to do some mods to the system if you are going to run it, J arm ball flip, dropped drag link and modify the torque arm mount the get the torque rod level to the ground. If you remove the torque arm or do not modify the mount you will get "brake steer" when you hit the brakes, it will pull to the right, the harder you hit the brakes the more it will pull. What happens is the axle rolls forward on the springs causing the draglink to push the "J" arm back, turning the wheels to the right.
"J" arms do break, especially if you hang the DS wheel in the air. Why, all the front-end weight is on the "J" arm and it snaps.
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #6 on: Aug 15, 2011, 08:43:54 PM »
so for the leafs and stuff, do i have to weld new brackets? and how big of shackles should i have? and if i do the ruf, would i need a new front drive shaft?
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
Re: step by step?
« Reply #7 on: Aug 15, 2011, 08:53:07 PM »
All your questions can be easily answered if you took the time and searched. Start here:
http://www.pirate4x4.com/forum/showthread.php?t=775780
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #8 on: Aug 15, 2011, 09:18:36 PM »
thanks for the link, ive never actually been on pirate :S
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
Re: step by step?
« Reply #9 on: Aug 15, 2011, 10:43:03 PM »
No worries, it can be kind of intimidating at first. Just read through the faq, tons of questions will be answered  :thumbs:
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #10 on: Aug 16, 2011, 09:51:26 AM »
haha thanks!  :bowdown: but one question, the double shackle, the one thats against the frame, is it welded there? or is it just free, so it can go down farther? and im not too excited, i have to have this done by  august 25th for hunting season, and i also have to get a bumper made and mounted, and a headache rack with a winch mount  :smack:
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
Re: step by step?
« Reply #11 on: Aug 16, 2011, 10:24:42 AM »
It's free, that allows you to get more droop when flexing. I've also seen setups where the shackle that lays against the frame can be bolted in place so it can't become unloaded unexpectedly.
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #12 on: Aug 16, 2011, 11:08:14 AM »
and i wont need new drive shafts right? sorry haha, i went thru all the stuff on pirate, but i forget what it says, and im off to work in like 2 minutes haha. also what shackles do you guys recoment? do u recoment the doubles? then should i also do the banana? also, could someone maybe draw me out what the dual shackles look like on paint or something, i just want to make sure i have it right, thank you
« Last Edit: Aug 17, 2011, 08:54:50 AM by jsimp »
OOPS
  • Male Posts: 2,561
Re: step by step?
« Reply #13 on: Aug 17, 2011, 03:21:34 PM »
You will need a long slip or a square D-shaft in the front.
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #14 on: Aug 17, 2011, 06:28:19 PM »
thanks!
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #15 on: Aug 21, 2011, 07:10:05 PM »
so, i got my rear end done, but i dont have the chevy springs in, my dad and neighbor refused to help me if i put those in, idk why, so i had to make my own leave package, and i added 2 1/2 inch blocks on the rear, and have 6 springs with the overload, its pretty stiff :/  and now i just have to do the front end, and a bumper then i can mount my winch!
87hillbillyoter
  • Turtle Points: -43
  • Male Posts: 1,066
  • Member since Mar '10
  • git er duuunnn!
Re: step by step?
« Reply #16 on: Aug 21, 2011, 07:12:19 PM »
wtf kinda bed is that?
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
jsimp [OP]
  • Turtle Points: 2
  • Male Posts: 111
Re: step by step?
« Reply #17 on: Aug 21, 2011, 07:14:52 PM »
costome made staneless steel, the guy that "restored" it made it, its pretty sweet, it takes some good hits haha
Last post Apr 06, 2006, 05:13:17 PM
by Crawler677
Last post Oct 23, 2007, 01:38:25 PM
by sinbob
Last post Aug 28, 2007, 04:26:04 PM
by *FFC*
Last post Oct 27, 2011, 09:05:10 PM
by THEMAN
Last post Dec 01, 2011, 07:58:07 AM
by crazykooter
