Spuds' 81 pickup
Started by spuds015, August 07, 2011, 08:42:11 PM
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
spuds015
Quote from: 4x4yota on December 20, 2011, 07:23:43 AM
fyi trail gear rear leafs end up totaling 4.5-5" of lift when installed.
most aftermarket options will net 1.5-2" higher than the spring size due to relocating the hangers and using loner shackles
a way to go would be to french the hangers to lower the height and run a shorter shackle
here is my 81 with 2" of lift and 33s and you can see it doesnt sit very tall so going with a 4"total lift wouldnt hurt but I do agree lower is better
thats perfect or could use +1inch. i got to thinking when u messaged me about the 51" yota springs u might use, for i didnt know they had that length before the crappy tacoma springs. maybe those with no overload and a 2" AAL or added springs from another pack would be perfect.
'81 pickup 5vzfe, r150f, 35's, welded 5.29's, f150 rear springs, Rears up front, TG dual adapter w/ 2.28's
4x4yota
thats the route I was gonig to try... loose the overload to get rid of the hang up hazard and add leafs since they are a naturally soft leaf...
the 3rd gen 51" springs will move the rear axle back about 3/8" and just have to relocate the rear shackle hanger or run a long shackle with stock hangers
Current:
Sold:
spuds015
sounds good. stupid question, which years are third gens?
4x4yota
89-95 4wd pick ups 2wds are about the same length but only 2 leaves and have more arch since they are spring under...
and you do have to press out and replace the busings since they use 14mm bolts compared to the 18mm that our trucks use
Current:
Sold:
spuds015
ill probly get 2 2wd packs and make a 4 leaf pack since they are arched more
4x4yota
Quote from: spuds015 on December 21, 2011, 10:41:19 PM
also before you buy them make sure that they are 51" flat length because some I looked at were still the same 48" as our stock
Current:
Sold:
spuds015
finally got my truck back from the shop. now it passes smog and is legally registered
4x4yota
Current:
Sold:
spuds015
#39
also got an AC compressor for OBA.
spuds015
no updates. just dicked around and made some poser shots with my buddys.
my buddys sammi with yj springs dual shackles, 6.5 tcase gear, and a 1.3L swift motor swap on 33-10.5's
spuds015
changed my mind and updated the parts to do list
spuds015
small update. GM 94amp 1wire alternator on
toyotanner
4x4yota
heck id be happy for a clean paint job
Current:
Sold:
spuds015
4x4yota
Quote from: spuds015 on March 12, 2012, 06:53:51 PM
rattle can :)
mine is rattle can and it doesnt have the shine Id like
Current:
Sold:
spuds015
no real updates. got a new job at les schwab busting tires, no more commuting 110 miles a day so hopefully i can start building this thing. got donor doors for half doors, new guide seals, gaskets and seals for the knuckles to put my diffs in, and replaced a blown out wheel cylinder. oh and a flowdisaster muffler so i can hear it now.
spuds015
Finally something update worthy. Put some kc's on. Got the knucles rebuilt and 4.56's in. Brakes and wheels will be the next step from here
81yota4x4
Its a nice looking rig hope to get mine up and going soon  :thumbs:
LETS ROCK :driving: :burnout:
spuds015
Almost forgot, got power steering too! Gonna have to say goodbye to my guns haha
dropzone
Add some sliders to your list
81 Toyota Trekker 221:1
spuds015
silders would be fantastic. Would 2x2x1/4 square tube be good enough?
tgmaul88
very sweet ride, x2 on the stock paint,  mines looking old and grumm,  i like where your going with this, ive had my yota over a year and its all still stock I havent even done power steering yet!  but keep up the good work  i wanna see where this will go,   im still running the stock 81 gears!  I do allot of highway driving with it on 30" 9.50 15
im debating to go efi or propane
yotacorps81
That's a good lookin truck! How did you do the power steering?
Life is like a good trail; Rough, dirty, and fun!
spuds015
Well I posted a wanted ad in the parts section. Got the push pull box from a guy in sac, someone else sent me everything but the box. Idk what years they came from but the pump fit pretty ok in the oem bracket, idk where the pressure line actually routes but it fits and doesn't leak so who cares. Did it all for less than $200 I can post pictures if u want
TheChewMaster
Quote from: spuds015 on October 18, 2012, 02:05:26 PM
Sweet, I'm the dude in sac........and that box is from an 82.
I'm glad to see ya got some progress done. Stay motivated, my heap is almost driving, works but still no drive shafts
spuds015
Unfortunately the yoga has been put on the back burner. been working on my 30 year project (my house) replacing drywall, floors, parts of the ceiling like this
Also sadly inherited a Flame Red 05 Neon srt4 from my mom
But i have managed to get some sliders on finally and 15x8 steelies. got my f150 leaf springs and have a set of 3in skyjacker fronts that I'm going to see what happens when i mix them with the rear pack
Updated pic
nisota
Nice first gen jealous of how clean it is Good luck with your build  :eye: :eye:
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
