v6 carrier in 4cyl third member?
Started by superyota, July 28, 2011, 11:37:28 AM
superyota
Is it possible to install a v6 carrier into a 4cyl. third memeber?  I know with arb's you can get the 4cyl. conversion bearings.  will the same conversion work if your trying to install a v6 carrier into a 4cyl third?  only reason why i'm considering this is i don't have the whole v6 third but might be able to find just the v6 carrier.  being the v6 carrier is stronger than the 4cyl, i'm looking into throwing an aussie in it and putting it up front in my 4cyl. third(if possible).  any info on this would be great.  thanks.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
SloCrawler
my rear end is a v6 spool in a 4cyl diff, i just had to special order bearings     :headscratch:
superyota
Quote from: Chrstphrtptts on July 28, 2011, 01:08:15 PM
ok, that should be the same thing.  so i'm guessing all i need then is the bearing coversion from v6 to 4cyl.  any idea what the bearings cost?
ABD Motorsports
#4475
KK6QDW
SloCrawler
i believe all air lockers are v6 carriers thats why they have the conversion bearings, I got mine through poly performance
superyota
Quote from: Chrstphrtptts on July 28, 2011, 01:16:23 PM
ABD Motorsports
#4475
KK6QDW
