My 69 FJ40 build: 1 Tons, atlas, 42's.. New pics
Started by awhotrods, July 24, 2011, 01:20:45 PM
awhotrods
Here is the 5.3 Vortec getting prepped to install
AaronB
jrock
You sure your not going to change the shackle angle? It looks a bit steep for the stage it's in.
pumkin toy
good reliable engine!  ive got one in my daily driver
97 4runner Limited
awhotrods
The springs will be shortened a couple inches
Quote from: jrock on June 01, 2012, 10:10:11 PM
superyota
Only a few months left to the roundup. You still planning on having it ready by then?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
awhotrods
Hopefully
Quote from: superyota on June 04, 2012, 07:26:30 AM
awhotrods
Finally got the motor/trans/atlas moved to the new shop and going to start mounting the drivetrain tomorrow.  Took a few pics of the cruiser before I loaded it up..
superyota
ABD Motorsports
#4475
KK6QDW
SloCrawler
thats one aggresive shackle angle ounce you load some camping gear..
awhotrods
Got the drivetrain all bolted together, should have it all installed by tomorrow.
jrock
awhotrods
Just started working on the drivetrain install again..  Took some time getting everything tucked up high enough, but I'm happy with the results so far.  Still have to build motor mounts and a crossmember but everything is mocked up for the most part.
awhotrods
Here is the tcase without cutting the floor, it would have been a rock anchor!!  Also a couple pics of the tcase mount, should hold up to plenty of abuse ;)
awhotrods
Got the drivetrain mounted and everything finish welded, I'm going to start working on the shock hoops and Fox 2.0's next.  Still trying to get this thing done for the roundup!   :headscratch:
awhotrods
 :gap:
awhotrods
 :beer:
awhotrods
Its pretty quiet in the FJ world  :inthedark:  Just ordered 4 shock hoops, hopefully yank the tub and get everything sandblasted and painted before I start putting it back together "for good"  :_oops:
superyota
Hurry up and get it done. Don't forget the motto, "quick and easy!" lol! Bring it up here when you get back from Michigan and I'll help you finish it up.
P^3! Lol
ABD Motorsports
#4475
KK6QDW
Dooner
Quote from: awhotrods on June 28, 2012, 04:53:01 PM
Haha! Your right we need to liven things up a little around here! The rig is progressing nicely, cant get over the huge difference clocking the Tcase up into the floor made.
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
awhotrods
Quiet as always in the Marlin FJ world, worked on the cruiser this past weekend..  Trimmed out the rear fenders for tire clearance, trying to keep as much of the corner as possible for now..
Jaysen
What do you use to trim? So it turn out so clean?
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
awhotrods
Tin snips and a sawzall
Quote from: Jaysen on July 30, 2012, 08:20:07 PM
Dooner
 Fenders turned out sweet! :biggthumpup: Diggin your welds, I vote for clear coating your frame rather than painting it! Bad ass drive train too :yesnod:
Cruiserhiggs
88 4Runner SAS 5.29's lockers 37's. 69 FJ40 350 swap 6" lift 35's work in progress.
awhotrods
I've been chipping away ar the 40 as time and money allow, picked up a used 8274 for 300 bucks, finish welded all the suspension/bumper mounts, mocked up the front end and installed the shifters.  Here are a few pics..
awhotrods
8274, going to put some work into this thing.  More pics to come..
awhotrods
#117
fixed the shackle angle
awhotrods
#118
front end mocked up, wheel base ended up somewhere around 108-109"
awhotrods
shifters installed
