FJ80 Linked 3rz Runner
Started by smacaulay, July 20, 2011, 01:40:44 PM
smacaulay
Finally got this thing wheelable...
smacaulay
Specs:
3rz w/ ~100k out of a 97 4runner - can't say enough about how good this motor runs!
Stock duals, twin stick
W56, marlin clutch
LC Header, stock (97) cat, flowmaster 40 - quiet, but sounds good
97 4runner dash/steering column and everything under it (still a work in progress)
FJ80 front - Hellfire knuckles/arms, arb's, stock birfs
14" 2.5 FOA's
2x2.5 FOA bumps
40" Xterrains
W/in the next month:
Going back to 37-38's
PSC high out put pump with hydro assist (stock pump gave up pretty quick)
DIY Beadlocks
smacaulay
Engine bay:
Interior...work in progress:
Peterbuilt84
You already have the hellfire knuckles or you plan on getting them? Thought they weren't out yet :dunno:
Sweet rig by the way  :beerchug:
John Doe
As many more detailed pics as possible. My 1st request it a pic looking straight down the side showing how much the tires stick out. What rear end are you running and whats the Back spacing on your wheels?
smacaulay
#5
Quote from: John Doe on July 20, 2011, 02:05:40 PM
I'll get more pics this weekend.  Wheels are 4.5" backspacing to suck the front in, 3" wheel spacers plus IFS rear to match.  Tires stick out maybe 3" if i remember correctly.
smacaulay
Quote from: Peterbuilt84 on July 20, 2011, 01:59:30 PM
I am business partners w/ Billy releasing these knuckles...these are prototypes being tested before release.  This was not meant as advertisement for the knuckles, just want to share my project with peers to get feedback.  I have a huge respect for Marlin Crawler and will remove all mention of our product if needed.
Also want to give BigMike and others here on this forum a big THANK YOU for all the 3RZ tech! My swap wouldn't have been possible without it.
Peterbuilt84
I see :thumbs: Didn't seem like you were advertising them at all, just caught my attention when I saw it. Been following the thread on pirate too.
But I've got to ask, how are they holding up?  :greengrin:
smacaulay
Quote from: Peterbuilt84 on July 20, 2011, 03:28:02 PM
They've been holding up great to 40" tires and a pretty heavy 4runner...very happy with the setup.
Peterbuilt84
Nice :smokin: Are you also running stock axles?
John Doe
Well I am in line for a set from the 1st batch. My wheels are only 3.5" so I'll be just a tiny bit wider though.
smacaulay
Quote from: Peterbuilt84 on July 20, 2011, 05:09:36 PM
Stock axles w/ no issues.
John Doe
How do you like the Power f the 3rz with the weight of your rig?
smacaulay
Quote from: John Doe on July 21, 2011, 02:06:05 PM
Good power in the flats, almost got it up to 80 (would have gone faster).  Descent grades I can hold 4th @ 65, steep grades I'm @ 55 in 3rd.  Overall street driving impressions are a lot better than the 22re (was 22re w/ 36's & 5.29's no exo), but I still wouldn't mind a little more power for grades.  This is part of the reason I may be dropping to 37's, plus it needs to fit in my garage a little better.
Wheeling-wise...this motor is awesome!  Motor runs very smooth and no overheating on hot days at low speeds w/ no shroud (3.0 radiator).
46&2
This 4Runner is sick as hell. Very nice work.  :smokin:
smacaulay
Quote from: 46&2 on July 21, 2011, 04:10:50 PM
Thanks 46&2!  Build took a long time and I had a lot of help.
smacaulay
Jaysen
baddasss runner love everything about it!!!
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
TacoRunner
www.4WHEELUNDERGROUND.com
[email protected]
toygasm
19864runner
You have anymore pics of the bad boy???????? Nice Rig  :biggthumpup: :biggthumpup: :biggthumpup:
smacaulay
#21
Thanks a lot for the comments guys, wouldn't have been possible without a ton of ideas taken from here :smokin:.
Finishing up the PSC 2.7 kit, should have pics in a couple weeks when I get back from a business trip.
Here's a couple pics in the meantime...
smacaulay
Totally forgot to get pics, here's the closest one I have to show how much the tires stick out (I'll try to get a better one later):
smacaulay
#23
Going to add a leaf in the rear, 2" shorter uppers in the front, then I'll be happy with the ride height.  Comparison to stock grand:
John Doe
Just curious, whats the ride height?
smacaulay
Quote from: John Doe on August 08, 2011, 09:03:49 PM
Was 27" to the frame by the rear tires, and 28" to the frame by the front...before the springs settled.  These tires are a lot bigger than i thought (measure out to a true 40" mounted at street pressure).
Its not super low, but feels pretty stable.  Once the spring mods are done, i'm hoping for 26"-27" to the frame on 40's w/ 3"-4" uptravel in the front.  I'll have updated measurements and pics when I get back in town in a couple weeks.
lownlinked85
What kit do you have in the front? or did you make the link kit yourself?
Low locked and ready to rock
smacaulay
Quote from: UnderConstructionProject 85 on August 09, 2011, 07:17:04 PM
The front was fabbed by a friend, no kit.  1.25" ruffstuff heims on the lowers/upper.  .75" heims on panhard and steering.
Most brackets also from ruffstuff..
smacaulay
Better shot of front setup (steering arms are rough cut mockup only, not production)
