sas axle what parts do i need for the axle
Started by Michael Wollinsky, July 18, 2011, 09:42:02 PM
Michael Wollinsky
I have the housing from a 85 it came with axles and birfs I have a third what else do I need I know knuckles but I'm lost
after that
Hand built and driving daily
Crawlin85
if the knuckles have spindles already all you need are hubs, new seals, and bearings
85 runner with cool stuff
-A truck with a body lift is like a fat girl in a mini skirt, it shows you everything you don't want to see
Michael Wollinsky
Can I use any of the parts off my ifs? hubs?
Michael Wollinsky
I searched and I couldn't find anything the the one one pirate I needed wouldn't work
Michael Wollinsky
No one knows what parts are interchangeable?
Crawlin85
yes you can use the IFS hubs to make front axle 3inches widers. i didnt know if you had auto or manual but use manual. pretty sure those are the only interchangable parts
Michael Wollinsky
So I would need the knuckle and spindle and just use my manual hubs?
Crawlin85
Sparkplug
Quote from: ol blue on July 20, 2011, 10:01:41 PM
No the wheel hub from ifs will swap over, with mods, not the locking hub, Search ifs hub mod on here and pirate.
Sparkplug
Quote from: Crawlin85 on July 20, 2011, 10:07:43 PM
affirmative
Wrong, sorry, im not a mod, but please dont post stuff unless your pretty well informed, or have seen it work, thats how misinformation gets spread
He would have to swap a solid axle hub gear into his ifs lock hub bodies for them to even fit over his birf, which would be a waste of time
Crawlin85
make sure knuckles have the trunnion bearing caps and to shim them properly. get hardened studs for the steering arms so you dont rip em out on the trail. their 9 bucks a piece from trailgear, i dont know if anyone else makes em
Crawlin85
my neighbors got a IFS hub and all he said he had to do was reposition the caliper to the other side of the mount and through bolt it
Sparkplug
Quote from: Crawlin85 on July 20, 2011, 10:15:53 PM
Yeah he has a ifs WHEEL hub, and a fj60 rotor with fj60 studs, and he had to grind his calipers, and drill holes in his knuckles. And he STILL is using a solid axle hub body, or a ifs one with a sa hub gear
Im not trying to be rude at all, just letting you know
Crawlin85
why not use a ifs rotor and caliper and skip all that bs?
Crawlin85
Quote from: Sparkplug on July 20, 2011, 10:11:02 PM
And apparently im more informed than you, Im running 86 toy ifs front discs and calipers on my 85 SA with 85 hubs and they bolted up just fine, no drilling or grinding needed. I just need to swap my 85 inner hub with the 86 inner i have laying around and ill be able to throw my spacers away. and reposition the caliper to the other side of the mount and through bolt it... where ever you got your info was from someone that did it the hardway
Michael Wollinsky
So I would need to rebuild my hubs could I use my rotors and calpiers
Sparkplug
Wow, this crawln guy. A toy axle consists of a HUB DIAL, HUB BODY, AND A WHEEL HUB. 3 different terms for 3 different parts.
Yes you can bolt a ifs rotor and caliper onto a solid axle sure, Better brakes. Thats not a ifs hub body or wheel hub on the solid axle.
Ol blue To put your axle together, stock way, without modding it or drilling, or swapping a SOLID AXLE HUB GEAR into you IFS HUB BODIES, Get the knuckles, spindles, wheel hubs and hub bodies from a solid axle truck. You CAN re use the hub dial from your ifs, also the calipers.
If you cannot find a solid axle hub body, you can order the longfield hub gear, and put it into your ifs hub body, but this will not allow youi to get the c clip on the end of your birf, without machining.
Michael Wollinsky
So just find a set of hubs off a solid axle spindles and knuckles?
Peterbuilt84
#19
This should help....
Edit: Look at this too > http://board.marlincrawler.com/index.php?topic=8872.0
junya92toy
Crawlin85
Quote from: Sparkplug on July 21, 2011, 01:43:20 PM
good job, said what i said with more detail...
Crawlin85
Quote from: Sparkplug on July 20, 2011, 10:26:14 PM
why grind calipers, why would you drill holes into the knuckle? and why fj60 studs?
dirtybird
Quote from: Crawlin85 on July 20, 2011, 10:45:57 PM
i think you can but that is just upgrading the brakes. purpose of IFS set up is so you end up with a wider axle so no need to use wheel spacers i think
dirtybird
Quote from: Crawlin85 on August 10, 2011, 01:55:33 PM
google brake upgrade for toyota straight axle or ifs hubs on straight axle
Crawlin85
Quote from: dirtybird on August 12, 2011, 11:26:24 PM
Is that only when you eliminate the wheel spacers? Im running the vented rotors and 86 calipers but still have the wheel spacers. but i never had to grind any calipers. just curious, I was gonna widen the front end without the spacers but after looking at the kits online it seems to pricy and the only reason to do it is to be able to use ifs hubs since solid axle hubs are harder to come by
