1988 toyota wheels 6lug
Started by 88monster, July 10, 2011, 08:31:07 PM
88monster
i have a 1988 Toyota pickup I'm buying some rims but need the correct dimensions i know its a 6 lug but is it a 6on127 6on132 6on135 6on165.1 6on4.5 6on5 6on5.5
They ask me what's it feel like to be stuck, I said I don't know I own a Toyota.
88monster
thanks any tips on bead locks i need them for 31'' on 15x8
Peterbuilt84
Beadlocks for 31's?
Type of beadlock depends on budget. You can get a diy kit, nice steel ones, or even aluminum if you have the coin.
88monster
i have the tires i need the wheels i have 800 to spend im doing a low budget 4x4 just 31s rear locker and MC twinstick try to make it look stock as much as possible i also have the MC twin stick and locker already
Peterbuilt84
No need to get beadlocks until you run bigger tires and low presssure imo. You can get a brand new set of wheels for under $200, then use the rest on other upgrades. Could probably find a good set of used wheels even cheaper.
88monster
true i could use for a chip air intake exhaust or whatever
RockRescue
were dose this CHIP you speek of go ?  i need 1 of these .
88monster
its for engine but it goes under the dash
88monster
it tells your ECU that your pulling more power into the engine
88monster
it doesnt mount under the dash i'm not for sure ill do more research m lil bro thinks he knows everything because he reads books and such he likes cars with v8 its different from a v6 truck sorry bout that
RockRescue
No worries i was just giveing you a bad time .  :therethere:
Quote from: 88monster on July 10, 2011, 10:08:38 PM
not on a 88 yota it dont
toyotech
hope your not talking about one of those ebay chips....  :shakehead:
88monster
ooh no i'm not buying an ebay chip i having toyota order me one and then my buddy install it
Quote from: 88littlestone on July 12, 2011, 03:16:48 PM
they do not offer a "chip" to increase power in a 88 toyota.  chevies yes, fords yes, honda's I'm sure, but your 1988 Toyota  :nope:
junya92toy
I got one already, sell it for half the dealer sells it
Snowtoy
Quote
The Dealer doesn't sell such an item.  The only company out there that sells a chip upgrade for pre-OBDII is JET electronics, and you have to send your ecu to them for them to install the new chip.  The chips in the Toyota ecu you have are soldered to the board, they are not a plug and play type chip.  The JET chip will work, but not enough by itself, you have to upgrade everything else like intake/exhaust, head/block work before you would see any real benefits from a chip upgrade.  If you have the 3.0, the upgrades are expensive and there are cheaper/equally priced alternatives that result in more HP/performance gaims.
daniresch
If you have 31"s and are trying to make it look as stock as possible, why don't you run factory wheels?
