MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
MiniSimp
Quote from: YOTA yota on April 06, 2010, 10:09:19 PM
Holy :pokinit:! Talk about rode hard and put away wet...
You must be new here. :gap:
Yes, it has seen a little abuse.
Wermz84
Quote from: MiniSimp on April 07, 2010, 06:21:46 AM
Yes, but usually just "Neglect"   :ha_ha:
I like to Drive!
MiniSimp
Quote from: Wermz84 on April 07, 2010, 07:38:59 AM
Deffinetly, since the last time it ran was April 2009 and sat outside under a tree since then... :gap:
Wermz84
Mine sat all this winter as well.  Time to change that.  :)
I like to Drive!
MiniSimp
#2644
Updating for my sanity
To Do List:
Finish welding front diff plug shut
Fill all Fluids
Tighten Driveshaft bolts
Torque 3rd member nuts
Test Drive through town
Pay neighbor kid to clean inside and out
Load tools/parts
Air up Trailer Tires
Load on Trailer
Fill water can with water
Fill Gas can with new gas
Aquire 6 pack of Bass
Fill radiator (close petcock first!) (Parked it uphill, filled with 1 gallon of AF rest water, started, filled more while running)
Torque Everything (steering arms & u-bolts were loose)
Air up tires to 5lbs (put 25 in em so I can drive it on the street first)
Fix winch power cable (quick fix for now, need to buy connectors)
Install Battery (finally bought the right size!)
Replace water pump (torqued to 9ftlbs and used ultra grey + paper gasket as per mfg directions)
tom w.
you need to prioritize.  :gap:
Quote from: MiniSimp on April 07, 2010, 10:01:41 AM
To Do List:
Fill all Fluids
Load tools/parts
Load on Trailer
BLACKDOG
:thumbs: good job Mini!
I can tell you were extremely careful to scrape off the bare minimum amount of caked on mud and grime when you installed the new water pump.  That ensures that there's plenty of mud and grime left to hold together the organ, as well as to integrate the new "organ" onto the engine, with little likelyhood of "rejection."
              -Ronald Reagan
MiniSimp
Exactly! I was thinking the same thing when installing it! :D
Dark Knight
mini, what is the "thicker leaf" for your bottom leaf (5th?) in the RUF? AAL?
*** YELLER ***
except BACON
MiniSimp
Quote from: Dark Knight on April 08, 2010, 08:08:30 AM
Came with the stock pack on the truck. Nothing special.
Dark Knight
hmmm doesnt look like an overload though...
I'll be doing the RUF with a pack from an 88 4runner. I'm thinking--> 88 main, 88 2nd, 88 3rd, 84 main cut down, then??? AAL or 84 2nd cut down... and cut the :pokinit: out of the fenders for some 35's (thats as big as you need on the right coast to do most anything)
MiniSimp
Quote from: Dark Knight on April 08, 2010, 08:20:10 AM
Just make sure the leaves are staggered evenly.
I would skip the AAL unless you want to be 10' in the air.
Dark Knight
Yes, want to stay low. When you say staggered enenly you mean, cut down to correct lengths matching the leaves above? (first build)
MiniSimp
Quote from: Dark Knight on April 08, 2010, 09:47:01 AM
Yes, each of my leaves is 6" shorter in overall length than the leaf above it. (3" each side)
1 - 48"
2 - 48" (wrapped leaf)
3 - 42"
4 - 36"
5 - 30"
Those are estimates, but should be pretty close to reality.
Dark Knight
brockbuilt85
advice from dave about holister:
"dont follow kyle and you should do ok"
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Wermz84
Quote from: brockbuilt85 on April 08, 2010, 01:50:02 PM
Why, because when he breaks down or gets stuck you'll rear end him?  :hahaha:
couldn't help it kyle.  lol
I like to Drive!
MiniSimp
No, it's because I only break in places that make the trail impassible! Always!
*** YELLER ***
Quote from: MiniSimp on April 08, 2010, 03:54:43 PM
yea because yer in the middle of said trail brokedown :slap:  :rofl:
except BACON
MiniSimp
Wermz84
Those have always been moments of High adventure.  :yesnod:
I like to Drive!
*** YELLER ***
Remember I'm not bringing my JEEP so dont get stuck :yupyup:
except BACON
subbrat
Hey does your neighbor have 220v in his garage?
MiniSimp
MiniSimp
To Do List:
Hammer a socket, or weld something to rear diff fill plug to loosen
Fill rear diff
Fill cases/trans
Fill engine oil
Fill front diff
Replace windshield washer fluid resevoir cap
Replace windshield wipers
Load tools/parts
Load on Trailer
Completed
Torque 3rd member nuts (spec is 19ftlbs, torqued to 240inlbs, all were loose front and rear)
Tighten Driveshaft bolts (rusted tight)
*** YELLER ***
except BACON
MiniSimp
MiniSimp
4 on the way.
*** YELLER ***
been there.... done that..... :yupyup:
except BACON
