MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
MiniSimp
*** YELLER ***
except BACON
MiniSimp
Updating for my sanity
To Do List:
Fill front diff
Load tools/parts
Air up Trailer Tires
Load on Trailer
Fill water can with water
Fill Gas can with new gas
Aquire 6 pack of Bass
Completed
Test Drive through town did a quick around the block drive and all seems good...well, as good as can be.
Replace windshield washer fluid resevoir cap (robbed the 2wd)
Replace windshield wipers
Pay neighbor kid to clean inside and out (took him 4 hours, he did a great job!)
Fill rear diff (took very little)
Fill cases/trans (took about 1 qt)
Fill engine oil (already full)
Finish welding front diff plug shut
Hammer a socket, or weld something to rear diff fill plug to loosen was able to use a short 15/16" 6 point socket with a mini-sledge to get it loose.
Torque 3rd member nuts (spec is 19ftlbs, torqued to 240inlbs, all were loose front and rear)
Tighten Driveshaft bolts (rusted tight)
Fill radiator (close petcock first!) (Parked it uphill, filled with 1 gallon of AF rest water, started, filled more while running)
Torque Everything (steering arms & u-bolts were loose)
Air up tires to 5lbs (put 25 in em so I can drive it on the street first)
Fix winch power cable (quick fix for now, need to buy connectors)
Install Battery (finally bought the right size!)
Replace water pump (torqued to 9ftlbs and used ultra grey + paper gasket as per mfg directions)
Slolyfe
Quote from: MiniSimp on April 12, 2010, 07:30:16 AM
To Do List:
Fill front diff
Load tools/parts
Load on Trailer
Completed
Fill radiator (close petthingy first!) (Parked it uphill, filled with 1 gallon of AF rest water, started, filled more while running)
6 pack????
You'll never take me alive
*** YELLER ***
except BACON
Slolyfe
my thoughts exactly. Steve and i will make up the difference.
*** YELLER ***
except BACON
MiniSimp
Quote from: Slolyfe on April 12, 2010, 09:44:40 AM
6 pack????
Yep :thumbs: I'm light weight. (well, in drinking terms)
Jud
Quote from: MiniSimp on April 12, 2010, 10:45:41 AM
HAHA don't feel bad, I'm sorta right there with ya, BUT once I start I can't stop. lol
"bout tree fiddy"
MiniSimp
our pictures from the Hollister Run: http://simpsonbrothers.net/Trucks/Hollister-Hills-416-to-4182010/
jrock's pictures: http://www.flickr.com/photos/39735732@N08/sets/72157623896294764/
My favorite from jrock:
Square driveshafts can support a 3000lb vehicle :gap:
*** YELLER ***
True but the second spring couldnt :yupyup:
except BACON
MiniSimp
Altenator, starter, pinion seals, front bumper mounts, front grill. Need to add belt mount bars to the cage and install 5 points with seats, stock seatbelts keep getting pinched between the body and cage. Will know more when I get it off the trailer. Time for a full maintenence teardown.
brockbuilt85
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Wermz84
Happy trails buddy.  :D
I like to Drive!
MiniSimp
*** YELLER ***
well that explains alot...
except BACON
MiniSimp
Well, it explains my flippy floppy bumper. :gap:
Blingn
Duffil
You having alternator troubles again? oughta just slap on a single wire Delco unit, ya know.
Wermz84
So i was just out working on the front of my truck, when i notice and wonder, why the front of my winch is leaning down instead of level.   Looks like I have the same problem.  :thumbs:
guess i need to pull the body off and beef it up after fixing the tabs.   :hahaha:
I like to Drive!
MiniSimp
Quote from: Wermz84 on April 25, 2010, 06:02:41 PMLooks like I have the same problem.  :thumbs:
Awesome. Yeah, I'm going to fab up some new mounts and plate bracing or something like that.
Wermz84
Why did the sound disappear half way through?
I love that spot. great place to warm up and test things out.
I like to Drive!
MiniSimp
Quote from: Wermz84 on September 23, 2010, 07:40:07 AM
:dunno: works fine for me. You should hire a computer tech to figure it out. :gap:
Wermz84
Quote from: MiniSimp on September 23, 2010, 07:52:24 AM
Well dang. I guess i should.  :disturbed:
You ever fix your bumper?
I like to Drive!
*** YELLER ***
except BACON
MiniSimp
*** YELLER ***
Holy Crap this this has cob webs all over it clean it up a bit would ya.....
what else do you need other that the welder
except BACON
MiniSimp
Quote from: ***YELLER*** on July 15, 2011, 10:30:49 AM
Have no idea, going to take a look at it tonight or tomorrow.
