Author Topic: Front third out?  (Read 3537 times)
rEdnECkwHeE1eR
  • Turtle Points: -68
  • Male Posts: 1,430
  • Member since Jun '02
  • Still tipin'
Front third out?
« on: Oct 04, 2002, 02:14:45 AM »
I would like to know the size of the hub socket and other unsual tools we might need.
-jack up truck take off tires
-drain fluid
-take off hub
-take off big nut within hub
-I think theres a step here
-un bolt spindle
-pull out birfied and axle asembly
-remove d-shaft
-remove third
-repeat in reverse order for asembly
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
Liquor up front
Poker in the rear
trt2
  • Marlin is the Man!
Re: Front third out?
« Reply #1 on: Oct 04, 2002, 03:15:18 AM »
26mm??  something like that...
remove the driveline while the fluid is draining.
two choices, go in from the hub side...
or go in from the felt wiper side.
either one requires pulling C clip.
on the hub side, remove the locking hub assembly.
remove the wheel bearing nuts (two with mallable lock washer between them).
Remove Caliper (loosen brake line) and hang off spring or somewhere.
Pull rotor assembly, bearing should fall out, catch it.
remove seal, backing plate and spindle, note where gaskets are (two paper, have replacements ready)
Pull birf
Do other side
now remove third member, use rubber mallet to break free.  Have new gasket ready.
On reassembly, seal your paper gaskets to one side only.  this way, when you take it apart on the trail, your gaskets stay put.
Suggest you inspect/repack steering arm bearings.  Literally remove the steering knuckle from axle end and clean it up.  Also, new felt wiper and what not on inside.
You're there, you might as well tag it all.
have lots of disposable shop towels ready, parts cleaner and a long afternoon.
take care...
Tony
Round Up M.C.
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #2 on: Oct 04, 2002, 04:10:44 AM »
26? More like 52 or something - use a screwdriver ;)
Brandon Miller
RCRC, Sacramento, CA
hawaii500_1999
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #3 on: Oct 04, 2002, 06:06:54 AM »
i think i paid 12 bucks for my socket at napa.  i don't know what size it is.  like brandon said, good ol screw driver and hammer works too.
have you ever removed cone washers before?  they are a pain sometimes.  i usually use a center punch in between the split.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
trt2
« Reply #4 on: Oct 04, 2002, 07:23:25 AM »
Yeeee....  26mm ... what was I thinking!!
Thanks Brandon!
ya, a screw driver works but after finally getting the hub socket, I replaced all those chewed up nuts.
Cone washers:  I found a good whack directly on the stud with brass drift and BFH usually gets 'em.
leave the nut on, right at the end of the stud, for thread protection especially if your using a small drift that might glance off.
and don't loose or toss those little cone washers, they're awful pricey if you have to replace.
take care...
Tony
Round Up M.C.
Brandon
  • Hawk
« Reply #5 on: Oct 04, 2002, 09:03:16 AM »
good idea to pick up a few extra tab lock washers from toyota, worth the buck or so to keep the nut from backing off...
Brandon Miller
rEdnECkwHeE1eR [OP]
  • Male Posts: 1,430
  • Still tipin'
« Reply #6 on: Oct 04, 2002, 11:17:31 AM »
Whats the name of the gaskits we need?
Liquor up front
Poker in the rear
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
« Reply #7 on: Oct 04, 2002, 12:04:27 PM »
gaskEts
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
    • MTA
« Reply #8 on: Oct 04, 2002, 12:09:36 PM »
Ok  :help:
You can get a Toyota kit for the front end but it does not include the following
Rear or inner wheel bearing seal
Inner axle seal
Marlin and others sell kits with those in them I think.
If you want to go budget replace any thing worn looking and the inner axle seal. reuse the rest and do not use silicone. If it had it before, you will most likely rip them getting it apart. The felt wiper may need replacing too, but the rubber one is more omportant.
« Last Edit: Dec 31, 1969, 04:00:10 PM by -1 »
rEdnECkwHeE1eR [OP]
  • Male Posts: 1,430
  • Still tipin'
« Reply #9 on: Oct 06, 2002, 03:16:20 PM »
it has a brand new felt wiper already
Liquor up front
Poker in the rear
rEdnECkwHeE1eR [OP]
  • Male Posts: 1,430
  • Still tipin'
« Reply #10 on: Oct 08, 2002, 03:52:24 PM »
ok now with reinstall
Any precautions or hard things to watch out for
Liquor up front
Poker in the rear
rEdnECkwHeE1eR [OP]
  • Male Posts: 1,430
  • Still tipin'
« Reply #11 on: Oct 08, 2002, 04:01:38 PM »
by the way its a 54mm and for the cone wasers I used a big brass punh that kind of fit in the hub goove for the cone washers. ill try a punch in the washer grove next time. And for beginers when you get to pulling the birf and axle mak sure the flat spot lines up with the little thing under it that prevents it from coming out if its not lined up
Liquor up front
Poker in the rear
Last post Feb 10, 2003, 12:21:34 PM
by greenmachine
Last post Feb 10, 2004, 08:29:53 PM
by gferris5
Last post Sep 02, 2002, 10:12:43 AM
by cruzila
Last post Jul 18, 2002, 04:05:17 AM
by hawaii500_1999
Last post Jun 11, 2002, 11:18:01 AM
by toymachine
