Author Topic: A340F not shifting  (Read 2436 times)
Blk Scout 800
  • Member since May '11
A340F not shifting
« on: May 30, 2011, 06:01:08 PM »
Hi guys long time PBB member here. I'm looking for some help with a 97 T100 Auto my buddy put behind a 22re in a 86 runner that had a A340H in it.
The swap is done and it drives great some of the time. Sometimes the auto will not shift no matter what we try. It will always manualy shift from first to reverse but no other gears. You can be driving down the road and it shifts great, pull up to a stop light and take off again and it wont come out of first no matter how high it's reved up.
Any thoughts on what I should do??
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: A340F not shifting
« Reply #1 on: May 30, 2011, 07:17:24 PM »
it sounds like its not getting a good signal to the transmission computer :dunno:
Blk Scout 800 [OP]
« Reply #2 on: May 30, 2011, 08:43:35 PM »
Ok so I need to check all my conections?
Could the VSS be bad?
Quick Draw
  • Male Posts: 250
  • Member since Feb '10
  • Her name is Doris.
« Reply #3 on: May 30, 2011, 09:04:49 PM »
Out of curiosity, how did you make that work?  The 22RE has a separate TCU, and an A340F is usually controlled by the engine ECU.  So that's where I'm confused.  It doesn't seem like a very straight forward swap.  I'll go with electrical just based on that, but who knows.
A VSS is easy to test.  With a continuity meter attached to both leads, spin it and it should give you continuity exactly 4 times per revolution.  And then make sure that it is receiving 12 volts.
Also, a lot of people don't realize that the A340F needs two different speed sensors.  One of them is in the transmission and the other is in the combination meter.  That could be a problem.
EDIT:  One more thought.  I have heard that shift solenoids going out is a common problem.  This is a possibility since the problem seems to be intermittent.  They work on a system of 2 solenoids.  First gear is #1 on #2 off.  Second is #1 on #2 on.  Third is #1 off #2 on.  Fourth is #1 off #2 off.  That may help you to determine which one is the problem.
« Last Edit: May 30, 2011, 09:15:03 PM by Quick Draw »
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
Blk Scout 800 [OP]
« Reply #4 on: Jun 01, 2011, 07:53:24 PM »
What is the combination meter?
Quick Draw
  • Male Posts: 250
« Reply #5 on: Jun 03, 2011, 09:34:01 PM »
The gauge cluster...  The thing with the speedometer, temp gauge, etc.
Blk Scout 800 [OP]
« Reply #6 on: Jun 05, 2011, 12:47:24 AM »
Ok well we are running the stock cluster so that maybe a start.
Has anybody else done this swap on here?
I came here after many long talks with Marlin himself and he said this was the swap I needed to do.
Last post Jul 12, 2004, 03:29:46 PM
by kyle_22r
Last post Jan 19, 2004, 12:18:52 AM
by 84runner
Last post Feb 21, 2005, 02:46:20 PM
by tryn2Crawl
Last post May 31, 2005, 10:21:21 AM
by dirtyskivies
Last post May 25, 2007, 09:22:41 AM
by jrock
