Will Marlin Vehicle Speed Sensor mate to the stock Toyota Electric VSS?
Started by Dmclat, April 26, 2011, 12:33:03 PM
Dmclat
I need to eliminate the stock Toyota Electronic VSS due to the fact it faces backwards and the plug will be in my way for a driveshaft mounted E-Brake
I want to buy the Marlin VSS adapter and try to mate it to the stock Electric VSS.
My question is do you know if the Stock Electric VSS will pull apart into two pieces so I can scew the Marlin adapter to it?
Dmclat,
Our VSS sender is more or less a mechanical-to-electronic speed signal converter. It has a female threaded end that attaches to a threaded mechanical sending unit. The aluminum boss of the Toyota RF1A electric sender does not have a threaded end and therefore our VSS will not attach to it regardless if you open it up or not. If possible, you would need to use JB Weld or some other hokey method of somehow "gluing" our VSS to your aluminum boss which I would certainly not endorse.
Please take a look at the following pictures which I believe will be of great help.
Here is our VSS with the mechanical speed sender that it is designed to attach to:
Here is our VSS attached to the above mechanical sender. This is the intended use of our VSS where it provides a digital output to a mechanical sender:
Here is the comparison of our VSS mechanical/electric "hybrid" setup to your electric Toyota sender:
I believe this last picture shows how our VSS sender requires a threaded male end for proper attachment, which the Toyota electric sender does not have any provisions for.
It is true that the Toyota electric VSS has a nylon gear connected to a rotating shaft -- similar in design to the mechanical sender -- however you will have to come up with some backyard peanut butter + bubble gum fabrication skillz in order for our VSS to function with the Toyota electric VSS.
Instead, I strongly recommend you put your electric VSS up for sale, because it costs over $200 new from the dealer, and then get a mechanical sender, as shown in the first 2 images, which are seriously a dime a dozen.
Additional reading on our VSS and its compatibility may be found in this thread: New Product - Marlin Crawler Vehicle Speed Sensor
Thanks and good luck Sir!
Regards,
Dmclat
Thanks a ton BigMike, My next question you answered already.....
I am going to pull a Mechanical sender out of my parts truck, mate it to your VSS adapter (that I will now purchase) and throw it back in.
Sounds great!! Please let us know how it goes and if you have any other questions!!
mudaddict
Mike, Thanks for the info I was talking with nick over there the other day about this trying to figure it out and see if you guys had something that would work.
I work At
All Pro Off Road
